Air Filter Issues
Old Jul 16, 2006 | 03:04 PM
TheBoar's Avatar
TheBoar
4th Gear
Default Air Filter Issues
I have a 1968 327 that has been rebuilt with a high rise intake. The hood closes, but the filter case rubes the inside of the hood. I'm currently using a 3" high filter. I tried a 2 1/4" that fit great, but the car lost it's performance.
What I'm thinking is trying a 2 1/4" high filter with K&N's top filter instead of the chrome cover. Does anyone have any experience with this type of filter and would it be able to pull as much air as the 3?
Please let me know, thanks!
Old Jul 16, 2006 | 07:03 PM
marshrat99's Avatar
marshrat99
Summit has a 2 1/2" x 14" K&N knock-off filter that I've been using it without issues. However, I don't think that I'd see any noticeable performance differences the way I drive between the 3", 2 1/2" or 2 1/4". Maybe if I was on the strip or dyno then I'd see a difference.
Old Jul 16, 2006 | 07:50 PM
sly vette's Avatar
sly vette
Have you tried a drop base air cleaner?
Old Jul 16, 2006 | 09:38 PM
Tonys96's Avatar
Tonys96
K&N claims the top is good for an extra 500 CFM.
Would be a good choice for limited clearance. If you decide you need more down the road, it's time for a new hood.
Old Jul 17, 2006 | 09:33 AM
TheBoar's Avatar
TheBoar
4th Gear
I have tried the drop base version and I'm currently using it. The last thing I want to do right is get a new hood (recent projects have zapped most of the car repair funds - ugh). I'll have to give the K&N a shot. Thanks for the help!
Old Jul 17, 2006 | 09:35 AM
rponfick's Avatar
rponfick
I agree with Marshrat, I doubt any change in perceived performance could be blamed on a change in air filter size.
Old Jul 17, 2006 | 10:38 PM
Sayfoo's Avatar
Sayfoo
Reguarding the K&N filter top. I run a 2 1/2 filter on my 69 bb, 390 hp., in order to keep from rubbing the hood. When I ran the car on a dyno, the operator removed the solid top after the first run, and the hp and tq went up ab out 5%. So, I put on a K&N filter top. Ran the car through again to get the carb adjusted to the correct af ratio. With the filter top, the figures were about the same as no top at all, so I think it does help if you have a restrictive or small filter. Also, kind of weird, when they changed to rods to get the "correct" af ratio, it lost power. Best power was when running about 10% richer then "optimum".
Old Jul 17, 2006 | 11:14 PM
comp's Avatar
comp
Old Jul 18, 2006 | 09:15 AM
TheBoar's Avatar
TheBoar
4th Gear
I acutally talked with K&N. With my 327 at 5,000 rpm, the af on a 14"x3" is 791 cfm. With the 14"x2 5/16" it is 609 cfm. The top adds 169 cfm. So by adding the smaller filter to the top (total of 778cfm) I can get pretty close to the 3". They said that there is 6 cfm per inch squared.
To Air Filter Issues
