Transmission conversion
Old Jul 18, 2006 | 06:32 AM
Phil Zell's Avatar
Phil Zell
Default Transmission conversion
Hi all,
I have a 350 out of an automatic 75 that I am installing into a 1983 El Cameno. The El Cameno was a V-6 with a 3 speed manual on the floor. Question is will the flywheel from the V-6 work with the 350 install, It appears that the flywheel will bolt up ok. Will there be a balance issue here?
Thanks in advance
Old Jul 18, 2006 | 06:39 AM
RHD '68 L89's Avatar
RHD '68 L89
Don't fergit the spigot or pilot bush in the back of the crank. It holds the input shaft in line with the crank.
Old Jul 18, 2006 | 07:09 AM
Phil Zell's Avatar
Phil Zell
Thanks for the headsup, got the pilot bearing installed.
Old Jul 18, 2006 | 10:57 AM
sperkins's Avatar
sperkins
Hey Phil - How about some more pics of the '68 vert!
Old Jul 18, 2006 | 11:30 AM
Bob Onit's Avatar
Bob Onit
I would be concerned with starter issues. Flywheel diameter/teeth ect:
I put a 300 HP 350 in a 81 ElCamino that was originaly a V6 and I had a few problems
Tha first thing you will need to do is make sure you install the stantion plates for the motor mounts Exactly where theyre supposed to be
#2 is.. you will certainly need new coil springs in the front as the V8 will cause the nose to drop quite a bit and your handleing will be very poor
*EDIT* IM confused, Are you changing engines or just transmissions?
When you say 350 I dont know if your talking about a 350 CID engine or a TH 350 Transmission
Old Jul 18, 2006 | 11:56 AM
markdtn's Avatar
markdtn
I can't remember exactly, but I'm thinking the V6 was balanced different than a small block. As cheap as a flywheel is (and as hard to change), I would just get one for a small-block.
Old Jul 18, 2006 | 09:08 PM
Phil Zell's Avatar
Phil Zell
email me, plenty of pics, I sold the car to another forum member, but it is still in my town.
philzell@msn.com
Old Jul 18, 2006 | 09:13 PM
Phil Zell's Avatar
Phil Zell
350 CID,
Thanks for the input, this car belongs to a friend of mine and I am helping him with it. I had not thought of the coil spring thing, but you are right. They sell the different motor mounts locally. That little V-6 was an absolute bear to get out. I believe we will have to get the different flywheel. The 6 banger has the 153 tooth and I don't believe it will work.
Old Jul 18, 2006 | 09:20 PM
Phil Zell's Avatar
Phil Zell
Bob,
There are a lot of holes in the crossmember, Do you remember exactly where the stantion plates mount?
Old Jul 19, 2006 | 12:23 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by Phil Zell
Bob,
It was many years ago but I do know that I measured another V8 ElCamino and for some reason wound up welding the stantions in rather than bolting them.
I dont think it was a problem as far as where to bolt them, I just think it was easier to use my Mig welder than to bolt them in
Another thought... are you leaving the stock 3 speed manual tranny in?
I doubt...sorry I know.... It wont stand up to the torque that the V8 produces
To Transmission conversion
