Quick 1981 Carb question
Old Jul 19, 2006 | 09:23 AM
hensen1954's Avatar
hensen1954
Default Quick 1981 Carb question
If this carb was originally hooked up to a puter - will it work Ok without one - or should I go totally aftermarket ??
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Need answer in just over an hour...
Thanks,
Hugo.
Old Jul 19, 2006 | 09:25 AM
Schwee's Avatar
Schwee
It needs a computer. But there are plenty of pre-1981 non-computer Q-jets out there. Keep looking.
Old Jul 19, 2006 | 10:19 AM
hensen1954's Avatar
hensen1954
Thought so - many thanks for saving my money - I owe you a beer !!!!!
Old Jul 19, 2006 | 10:55 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
but it should run without the computer system. It'll just run rich. You also need to deal with the distributor since the timing advance is run by the computer as well.
Old Jul 19, 2006 | 11:31 AM
SIXFOOTER's Avatar
SIXFOOTER
If the carb is not completely bollaxed or missing it will save you $$ to fix it (provided the ECM is still operating)
Old Jul 19, 2006 | 03:16 PM
Kalway's Avatar
Kalway
Short answer is yes it CAN run without the computer. However, it'll run like crap without it. If your computer or any of the sensors are hosed it's sometimes easier to just go to a non-computerized system. However, if everything in the system but the carburetor is working fine then just repair/replace the carb. The system isn't that bad when it works.
Old Jul 19, 2006 | 03:20 PM
hensen1954's Avatar
hensen1954
Everything else is gone..........
Old Jul 19, 2006 | 03:39 PM
xlr8shn's Avatar
xlr8shn
Thanks,
Hugo.
Oh so you're the one that stole it from me....
Let me know if you dont end up using that carb. I didnt want to spend much more than $50-$75 shipped for it.
Just ribbin' ya.
Old Jul 19, 2006 | 04:43 PM
palazzopl's Avatar
palazzopl
if the computer is gone the transmission torque converter will not lock up.. if you want it to lock up you can get a kit from bowtie or use a switch and ground the test connection under the console near the cig. lighter
Old Jul 19, 2006 | 05:57 PM
xlr8shn's Avatar
xlr8shn
Or you could use one of these to automagically lockup the TH350-c converter...
http://store.summitracing.com/egnsea...0&autoview=sku
Old Jul 19, 2006 | 06:56 PM
hensen1954's Avatar
hensen1954
Need something - - - - the fuel consumption at the moment - c'est terrible !!!
Would prefer a Spanish 6 speed.
Old Jul 19, 2006 | 08:15 PM
xlr8shn's Avatar
xlr8shn
Spanish 6 speed? Is that anything like a Spanish fly?
/me ducks
Old Jul 19, 2006 | 10:43 PM
Richieboy's Avatar
Richieboy
Will we pass CA visual inspection if we go to a non comp set up? Ive got an 81 as well. I think it would be hard for them to tell the difference, but then I'm new to the vette technology.
Old Jul 19, 2006 | 11:07 PM
Kalway's Avatar
Kalway
If you're creative you could. You'd have to set a timer for the check engine light to come on when you start it up and it has to turn off after a few seconds. Other than that, they'd be hard put to tell any difference.
Old Jul 20, 2006 | 01:41 AM
CA-Legal-Vette
Unless you get someone that really knows what they're looking for, all they need to see is a "check engine" light come on and then go out . As long as you pass the sniffer, you should be fine. The cat and the air injection should get you there.
To Quick 1981 Carb question
