SIZE radiator...please help
Old Jul 19, 2006 | 01:17 PM
gtsvette's Avatar
gtsvette
Default SIZE radiator...please help
what is the lagest radiator in size that will fit in a 77 corvette..
it looks like i can fit a 33" x 18-19 "
Old Jul 19, 2006 | 01:54 PM
BarryK's Avatar
BarryK
don't know the exact measurements......... but just order a direct fit aluminum rad from Tom DeWitt and it's guaranteed to be a perfect fit with no problems!
The best fitting, best quality rad you can purchase for a Vette
Old Jul 19, 2006 | 02:16 PM
bruced267's Avatar
bruced267
Old Jul 19, 2006 | 02:28 PM
gtsvette's Avatar
gtsvette
the problem is i have an olds 455 in the car and wanted max cooling ... you think a corvette rad will cool the 455 motor???
Old Jul 19, 2006 | 02:59 PM
SIXFOOTER's Avatar
SIXFOOTER
same dimentions will work fine
Old Jul 19, 2006 | 03:39 PM
gtsvette's Avatar
gtsvette
ok cool.. i odered a rad from griffin spec size 31x19
Old Jul 19, 2006 | 08:47 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Huh?
Old Jul 19, 2006 | 10:32 PM
Jclgodale3's Avatar
Jclgodale3
How much?
Old Jul 19, 2006 | 11:20 PM
gtsvette's Avatar
gtsvette
$$$$259.00
Brand: Griffin Thermal Products
Product Line: Griffin Aluminum Circle Track Radiators
Radiator Style: Crossflow
Overall Width (in): 31.000 in.
Overall Height (in): 19.000 in.
Overall Thickness (in): 3.000 in.
Row Quantity: Dual-row
Radiator Finish: Natural
Radiator Material: Aluminum
Transmission Cooler: No
Inlet Location: Upper driver side
Inlet Size: 1 1/2 in.
Outlet Location: Lower passenger side
Outlet Size: 1 3/4 in.
Tube Size: 1 1/4 in.
Fan Included: No
Quantity: Sold individually.
Radiator, Universal, Aluminum, Natural, 31 in. Wide, 19 in. High, 3.0 in. Thick, Each
Check to make sure this part fits your application
Radiators built for the track.
When time is crucial and weight means everything, let a Griffin aluminum Circle Track radiator give your high-powered race car the advantage. Manufactured with lightweight aluminum technology, these radiators are designed in a wide variety of racing sizes for your cooling needs. The Griffin design incorporates open-fin spacing that promotes airflow through the radiator to enhance the cooling and help eliminate clogging.
Old Jul 19, 2006 | 11:21 PM
gtsvette's Avatar
gtsvette
Originally Posted by Tom DeWitt
Huh?
CAN YOU HOOK ME UP ??
Old Jul 19, 2006 | 11:26 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
$$$$259.00
Thats the same one i have. It takes a little work some grinding and such to make it fit. No problem for someone who has the skills to slide an olds 455 into a vette.
I feel its important to get the 1.25" tubes to get the extra capacity and thermal transfer. The 1" tube 2 row is $180 but i wanted to go as big as possible since this car has had overheating problems since day 1.
Still waiting for pictures of your engine compartment.
To SIZE radiator...please help
