TH400 stuck in first!?!?
Old Jul 21, 2006 | 03:44 AM
johnnybrewmeister's Avatar
johnnybrewmeister
Default TH400 stuck in first!?!?
My '73 auto with a TH400 seems to be stuck in first!!!
I just recovered from 3 months downtime replacing radiator+hardware+misc. and took it for a drive tonite.
Now my tranny seems to be "stuck" in first - in double quotes because reverse, neutral work fine. But any forward motion seems to be stuck in first gear.
My tranny fluid was a bit low, because I spilled some during the radiator removal/replacement. So I topped it off but it didn't seem to help.
I took it for many test drives, manually shifting, revving high, etc. trying to "un-stick" it, but no luck.
Any guesses/suggestions? Can't really be related to 3 mos. downtime, can it?
Old Jul 21, 2006 | 04:18 AM
Meh's Avatar
Meh
Check your vacuum connection to the vacuum modulator.
Old Jul 21, 2006 | 06:49 AM
worship79's Avatar
worship79
Old Jul 21, 2006 | 07:44 AM
noonie's Avatar
noonie
If it's not the modulator valve then it's tome for a rebuild. Seals inside are shot.
When you have exhausted all other possibilities, you may try 2-4 oz. brake fluid. Sometimes this can swell the seals enough to make it work for a while.
Old Jul 21, 2006 | 11:03 AM
lars's Avatar
lars
Pull your governor out and check the governor wieights, the valve in the governor, and verify that the governor gear has not "apple-cored." If the governor has any problem, the tranny will think that the car is either not moving or miving very slow, and it will not allow the TH400 to shift out of 1st.
A bad modulator will produce high shift points, but the tranny will shift at very high rpm.
Old Jul 21, 2006 | 03:52 PM
Little Mouse's Avatar
Little Mouse
Sounds like the rubber hose has come off down on the modulator.
without vacuum to it your car will not shift out of low gear. I had
mine come off a couple times on a turbo 400 pickup. Pickups set high off the ground just reached up underneath stuck it
back on had three gears again.
Old Jul 21, 2006 | 09:59 PM
johnnybrewmeister
Can somebody give me a clue on where to look for this???
It sounds like the common "first thing" to check, and simple enough, but I"m clueless.
I'll start doing some research...
Old Jul 21, 2006 | 10:13 PM
noonie's Avatar
noonie
Old Jul 21, 2006 | 10:14 PM
Little Mouse
the valve is round and on the right side of your trans. it will have a very short hose atached to a metal vacuum tube that runs from it
up to a vacuum source on your intake manifold check the hose at
round mod. valve side to see if it has come off or if it has become rotted and split at the end. if there is nothing wrong at the mod. valve end, check
the small length of rubber hose up on the intake manifold end.
Old Jul 21, 2006 | 10:17 PM
Little Mouse
pictures are good
Old Jul 21, 2006 | 10:26 PM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
Had the exact same problem. That is what I would check first.
Old Jul 21, 2006 | 10:43 PM
johnnybrewmeister
Thanks! Thanks noonie for the pic too! This forum is awesome.
The good news: yep, this is my problem - I have about 5" of hose on the tranny side; how it got cut/shortened/snapped isn't obvious. So this will be a cheap fix.
The bad news: since the hose is broken, not just loose/removed I won't be able to fix it in time for tonite's date-nite.
I hate to be so clueless, but can I get more details on where the other end attaches to the intake manifold?
Old Jul 21, 2006 | 10:53 PM
Little Mouse
you will be able to tell where it goes after you remove your air
cleaner.
Old Jul 22, 2006 | 04:18 AM
johnnybrewmeister
aha, thanks Little Mouse.
I finally found a decent page in the assy. manual, removed the air cleaner, and then re-read your post again. I was confused on how much of the hose was supposed to be rubber, and how much of it was a fixed metal tube. I think my 4-5" piece of rubber hose on the tranny end just came off, and needs to be reconnected. I'll try it tomorrow and report back (just in case anybody else is like me, and searches the old posts for good data).
To TH400 stuck in first!?!?
