82Collector
Old Jul 21, 2006 | 10:27 AM
warrior2291's Avatar
warrior2291
Default 82Collector
Hey has anybody eer had a problem with their lightsa on the dash and gages being dim. I replaced all the bulbs and I even put a new headlight switch but it was no help!
Any advice and directions would be helpfull
thanks
Old Jul 21, 2006 | 11:27 AM
bluesilver82's Avatar
bluesilver82
Same Probelm....Bad Battery. Could be your problem?????
Old Jul 21, 2006 | 11:33 AM
75BrownC3's Avatar
75BrownC3
Is the alternator putting out enough current? You may want to check that.
Old Jul 21, 2006 | 11:34 AM
warrior2291
Default 82collector
I put a new battery in as well
Old Jul 21, 2006 | 11:56 AM
rudolph schenker's Avatar
rudolph schenker
Same problem with a 82
Old Jul 21, 2006 | 02:03 PM
bluesilver82
I have recieved bad brand new batteries in the past. I have had this problem specifically with exide batteries. Check the battery.
Old Jul 21, 2006 | 11:29 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Avoud exide with all costs.. Back in the day batteries would give 5-7 yrs of life now your lucky to get 3 yrs or 3 days ..
Old Jul 24, 2006 | 07:30 AM
warrior2291
Default corvette82 collector
I checked the battery this weekend and yes it is good I will check out the alternator this weekend , by the way I see that there are a couple of ways to buy alternators. I see a 70 amp and a 55 amp can they be swaped does it matter which one you use?
Old Jul 24, 2006 | 10:05 PM
Madness82's Avatar
Madness82
I would also check your battery cables at both ends and clean w/ a wire brush if necessary.
Old Jul 25, 2006 | 12:07 AM
C3Racing's Avatar
C3Racing
thanks
Lets start over how dim is dim?
Old Jul 25, 2006 | 07:07 AM
warrior2291
Dim is that I can see the gages but they are not as bright as they should be with the dimmer switch turned all the way up. I put a new battery and a new dimmer switch in. I also check the cables and they are clean .
I bought new bulbs and put them in also.........
Old Jul 25, 2006 | 09:16 AM
...Roger...'s Avatar
...Roger...
First thing I would do is remove 7.5 inst.pnl.lps. fuse and clean its contacts and the end of the fuse-all the illumination lights goes thru it.
Second I would check the ground for the instument panel-its on the left pillar post above courtesy light
Third-this is to check my second point-run a wire to ground side of battery and take other end and scratch around on bottom of speedo or tach case just to make sure its grounded
Fourth--(And naturally watch dash lights to see if any of this makes them brighter)
I hope this helps if it doesnt I have a couple other things to try.
Roger
Old Jul 25, 2006 | 12:22 PM
warrior2291
Default 82collector
Thanks Roger i will try this tonight..............
Old Aug 4, 2006 | 02:08 PM
warrior2291
Default 82collector
Ok I put new alternator, new bulbs, new battery, and a new dimmer headlight switch.no joy.I tried all the things you told me to do and still no joy.my......... head is hurting
Old Aug 17, 2006 | 10:59 AM
warrior2291
Roger
Well i figured it out thanks to you.i found a loose ground wire after a liitle more trouble shooting and guess what they work fine thank you for the great help!!!!!!!!!!!!!!!!
To 82Collector
