Is this really necessary?
Old Jul 22, 2006 | 07:36 AM
7Deuce's Avatar
7Deuce
Default Is this really necessary?
I was reading the instructions for installing comp cams magnum roller tip rocker arms. Under the special instructions it states...
"the use of old pushrods may result in pushrod or rocker arm failure. It is necessary that you install new pushrods with your new Magnum Roller Rocker Arms to insure you rocker arm warranty. Pushrod ends have a mated surface to the racker arm ball socket, much like a cam and lifter mate to each other. This is why used pushrods cannot be run with new Magnum Roller Rockers."
Do you really need to change pushrods if you put on new rocker arms? Is this just a product specific thing (for the magnum roller rockers) or would you have to change the pushrods when installing any brand of rocker set even if keeping stock ratio, etc?
Thanks for any input.
Old Jul 22, 2006 | 07:37 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
on the valve train items if they recommend it i would buy it
Old Jul 22, 2006 | 08:11 AM
7Deuce's Avatar
7Deuce
Just looked up install instructions for Crane energizer roller rocker arms. Didn't say anything about changing the pushrods.
Old Jul 22, 2006 | 08:23 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
pushrods are cheap... a lot cheaper now than later..
just my opinion, your mileage may vary...
Old Jul 22, 2006 | 08:40 AM
ghoastrider1's Avatar
ghoastrider1
change the pushrods...they do get wear patterns...i have seen old ones slightly bowed as well....cheap insurance to change.
Old Jul 22, 2006 | 09:32 AM
SIXFOOTER's Avatar
SIXFOOTER
Yep, change em. Thats how my Dad tought me to do it
To Is this really necessary?
