whats is this part called
Old Sep 4, 2001 | 10:25 AM
GERALD's Avatar
GERALD
Default whats is this part called
what is this part in mounted in the vacun line from the vacum port on top on the intake manifold vacum line goes in threw the fire wall is this a check valve or what is it and what does it do this is on my 79
Old Sep 4, 2001 | 12:07 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: whats is this part called (GERALD)
It could either be a check valve or a vacuum filter.
A picture and better description would be needed for a better answer.
Old Sep 4, 2001 | 12:33 PM
PRNDL's Avatar
PRNDL
Default Re: whats is this part called (BSeery)
On my 68 first there is a white plastic filter (one hose in/one hose out), next is a metal check valve, similar size and shape, but one hose in, 2 hoses out. MJ
Old Sep 4, 2001 | 12:58 PM
Jim-K's Avatar
Jim-K
Its probably the check valve and filter for your headlights.
Jim-K
Old Sep 4, 2001 | 01:28 PM
GERALD's Avatar
GERALD
It's like MN Jacks 68 with the round metal one with one hose in two hose out I thank the round plastic one with one hose in one hose out may be a filter why it's use I don't no
To whats is this part called
