Never had this happen before, a very noticible shake occures in the front end between 50 and 65mph, and then again when slowing down from 70. smooth and straight before and after.
It's a 68 BB roadster, all new joints , bushings, steering box, front end alignment, new TA radials balanced 3 times so far. I've even put the rear tires on the front and it's not half as bad, but still noticeable.
235/70R15 rear 225/70R15 front. This shaking did not happen before the front end was overhauled. Thanks ahead of time for any help.
Gluntly
Something isn't right (obviously) I would get under there and go over everything with a torque wrench. My initial reaction was wheels/tires and it still may be your problem. Depending on where you got them ballanced they may not have the capability to correctly hi speed balance them. I can't remember what the name of the machine that was recommended in here a couple months ago for this. Someone will chime in. Also do a search on wheel ballancing. But my first step would be check torque on all the suspension components to make sure.
But also you said when you switch frt to back the problem changed-"follow that"-if you have a good spare swap with one of the tires that was on the frt when it shook the worst-then do the other one until you isolate the bad tire.-----Hey SIXFOOTER hows that parts installation coming along?
Almost ready to get on it. Still need to hook up compressor so I can run the new sandblast cabinet. First step is get all the cabinet projects out of the garage, thats happening this week. By Sat I expect to roll the vette in and start removing the front clip. Then roll it back in the driveway for a serious de-greasing and then pull it apart. Lots of pics will follow. I have about 300 lbs of parts all piled up on the bench and laid in a supply of Corona, ready to get on it.
Yeah thats a possibility also -the 68 even has smaller frt. wheel bearings-I wonder if the smaller bearings have a tougher time with bigger than stock tires-probably not.My gut feeling from his post and moving the tires I think he has a tire that balances staticly but dynamicly sets up a vibration at certain speeds.When he moved them back he didnt say if the vibration went from steering to seat of pants.
Gluntly
Either a balance or bad tire problem. Most likely a balance in that it is speed sensative.
I also have TA radials and have a lot of trouble. 2 out of the 4 original tires I had balanced 3 times. It ended up 2 of the 4 were out of round and no amount of balancing will fiix this. After fighting with the seller for 2 weeks I got replacement tires. The set I have now I have balanced 2-3 times, they are not to bad now but I am still getting vibration between 75-80. I am not happy with these tires and will not buy again.
Dennis
My first thought was bent wheel, had a similar problem with a wheel that was bent so slightly it wasn't visible. We just put Traction T/A's on my wife's Volvo, there is a vibration above 80 MPH that wasn't there before. Haven't gotten them rebalanced yet. Good luck.
I'd check for a warped wheel. Also check the hubs for distortion, play, or just crud that keeps them from making good contact with the brake rotor/wheel.
I was running Goodyears on my '73 and had a vibration that started about 55mph through 70mph. I had the car aligned, replaced the shocks, bought new Firestone tires, had rims trued, and replaced the idler arm. Everything helped a little, the problem went away altogether when I started playing with the tire pressure. I found that if I ran the tires a little below the usual 32 psi (but within manufacturers limits, I called Firestone to be sure) that the car handled better and did not vibrate at all. I'm running 29 psi in rear and 27 psi in front. I kept changing pressures and then test driving the car over the same fast lane of I-95. If your roads are like mine, don't do the test in the lanes the trucks use, even my family car has problems with the pavement there. Good luck, Bill
I had the same problem with my 73
Turned out to be two 33 year old rear rims were less than perfectly round.
Ordered 2 new rims and now its smooth from 25 to 125 mph!
i bet its a wheel bearing, i have the same problem in my 72 super beetle, i didnt seat the race in the drum all the way and it shook the steearing wheel and all.
Was the darn wheels guys, I picked up a set of mags on e-bay real cheap
on a whim (amazing) and had my TA's put on them, and smooth as glass.
Go figure, thanks again for all the info, I know I'll use some of it again sometime!!
