Does anyone make...
Old Jul 25, 2006 | 06:41 PM
bashcraft's Avatar
bashcraft
Default Does anyone make...
a drivers side alternator bracket for a BBC with tall valve covers?
Old Jul 25, 2006 | 08:10 PM
fl_rider's Avatar
fl_rider
Default Summit
http://store.summitracing.com/partde...5&autoview=sku
Hope this helps
Old Jul 26, 2006 | 07:33 AM
bashcraft's Avatar
bashcraft
Originally Posted by fl_rider
According to the description, this bracket is for use with a short water pump. I'm pretty sure my '69 has a long water pump. My problem is that I can't find a drivers side bracket for use with a long water pump.
Will it make any difference, or will I need to get a short water pump and new pulleys?
Old Jul 26, 2006 | 12:09 PM
BigBlockk's Avatar
BigBlockk
My '70 has a short water pump. The '69's and '70's were so much alike that GM didn't print a manual for the '70. I would bet that if your car has a long pump it ain't stock.
BigBlockk
Later.....
Old Jul 26, 2006 | 12:39 PM
bashcraft's Avatar
bashcraft
BigBlockk
Later.....
You're probably right. I had this 454 built to replace the 350 and the engine builder sold me the pump and said it's the one I need. It's aluminum and I think he said it was the long one. How can I tell to be sure? Is there something I can measure?
Old Jul 26, 2006 | 12:59 PM
S489's Avatar
S489
from memory:
short pump is 5-3/4" tall
long pump is 7-1/4" tall
measure from face of flange where fan connects to front of block.
if i got the dims wrong, someone will correct me; thanks
Old Jul 26, 2006 | 01:04 PM
BigBlockk's Avatar
BigBlockk
With the short pump on my LS-5 there is no visible clearance between the back of the pump and the timing chain cover.
BigBlockk
Later.....
Old Jul 26, 2006 | 01:11 PM
bashcraft's Avatar
bashcraft
Thanks guys, I'll check it when I get home, but if I remember correctly, I don't think there is any room between the pump and cover.
Old Jul 26, 2006 | 09:24 PM
Ironcross's Avatar
Ironcross
The stock OEM brackets. But it must be used with the short pump. Classic Camaro sells the OEM style also.
Old Jul 27, 2006 | 09:53 AM
bashcraft's Avatar
bashcraft
Well, I guess I misunderstood something because I do in fact have a short water pump. So, the bracket from summit should work for me. Now I just hope the pulleys all line up.
Thanks everyone for your help!
Old Jul 27, 2006 | 10:44 AM
Ironcross's Avatar
Ironcross
I have seen the Summit stuff on various cars. {street rods, Vettes and such} As long as you have the early short WP you would be better off with the OEM parts as it will not put the alternator up high over the valve cover with a bunch of rod ends to adjust it. Plus all your current pullys will line up perfectly and the belts will not come blasting off at high RPM`s. Very important to me as I`m always flirting with 7000+
Old Jul 27, 2006 | 10:53 AM
bashcraft's Avatar
bashcraft
I need to run tall valve covers because of the stud girdle. I'm afraid the OEM brackets won't let the alternator clear the valve covers.
Old Aug 1, 2006 | 02:18 PM
S489's Avatar
S489
bashcraft,
have any luck finding brackets that work?
i'm in the same process, different reason; figured i'd have to just cut and weld something. . .
Old Aug 1, 2006 | 03:37 PM
bashcraft's Avatar
bashcraft
I ordered the bracket from summit that fl_rider suggested above. From what I can tell, it's just what I need.
Old Aug 1, 2006 | 03:58 PM
S489's Avatar
S489
when i spoke to summit, the gentleman said that that bracket was intended to locate the alternator in the "stock" location, wherever that is! i like the looks, but my alt needs to be moved a little outboard and rearward from "stock". let us know how they work out on your vette; maybe post some pics too. . . thanks
To Does anyone make...
