I'm trying to remove my front coil springs on my
76. I bought two pickle forks from Harbor Freight and tried to use them to separate the ball joints from the spindle housing. I pounded them in all the way(about a half inch gap), and the spring still won't bust loose. I don't have an air compressor or impact tools , which makes this a very tough job for sure. Any suggestions please?
You are going to have to remove the spindle totally to remove the spring. The easiest tool I have found to get the ball joints out of the spindle is one of these separators.
Make sure you have the bottom arm supported by a jack because once those ball joints let loose the spring will want to pop out. Then you can slowly lower the jack until there is no tension left on the spring.
Here's what I did. I put a floor jack under the spindle and lifted it, the spindle, about one inch from where it naturally hangs. Then I whacked the spindle where it connects to the upper A-Arm. You need to hit it where the A-Arm slides into to spindle. The A-Arm popped loose and then I lowered the jack until the spring fell out. I also chained the spring in case it popped out.
Oh yeah, make sure all cotter pins are out and castle nuts are loosened but not off. This will keep the A-Arm from completely separating.
From: San Diego - Deep Within The State of CONFUSION!
Pickle fork won't do it. Use a good sized hammer and hit the spindle where the BJ goes through it. This temporarily elongates (makes it eggshaped) the hole and forces the joint out of the tapered opening.
Leave the nut on the joint, just loosen it. Leave the floor jack under the spring so there's tension on the BJ. Smack it hard and it will pop loose. *****BE SURE YOU HAVE A FEW THREADS ON THE NUT ***** to cover your butt.
Chris75, I bought a spring compressor today, but didn't think of using it! I was going to use it to install the new springs only. So what you're saying is to compress the old springs to the point that they'll just come out without pounding the ball joints loose?
You will still need to break the balljoints loose, you still have to get the new springs in! Be careful when using the spring compressor, if you tighten it too much the bolt will stretch and release the spring. I find an impact gun the fastest, easiest, and most importantly gentle way to compress the springs. Make sure you set it up in a way that you can remove it once in the car. Personally I find the "chain the spring in, use a jack on the lower arm" to be the safest and most controllable method.
They usially pop right apart, but you have to hit it HARD with a BFH.
Why spend all that time and energy whacking when this little $19 gadget from JC Whitney will pop them loose in about 30 seconds with almost no effort (it's the one on the left)?
My "pickle fork" bottomed out on the stud before the joints came apart, anyway.
You can go to a Checker, Schucks, AutoZOne and rent the kit that has all those seperators in it for a few bucks or free depending upon how long you keep it.
Most spring compressors don't fit very well, I built my own :
It's about $15 at HomeDepot, just get the better quality allthread. I got the cheap stuff, it works but grade 5 or 8 material would be safer.
It mounts thru the hole that the shock mounts to.... when you lower the control arm the spring remains compressed and then you release the tension by loosening the nut on the allthread...
Batman, that looks like the ticket. It makes me nervous for a rookie like me to swing a BFH around my fiberglass. I'll order it and give it a try
I recently replaced my front coils and didn't remove the BG's. We attached a spring compressor, unbolted the lower control arm from the frame and swung it out of the way and removed the spring. With the #550 coils I put in we did not even need the compressor. Used a floor jack to get the control arms back into position and bolted them up.
Following the Haynes Manual, I just changed my front springs by removing the shocks, disconnecting the sway bar, compressing the spring, and unbolting the lower dogbone (pivot cross shaft). The compressed spring came out easily. I compressed the new one and stuck it in place and bolted up the dogbone.
After removing the shocks and the sway bar, it take only about 1/2-3/4hour for each spring.
You need one of the spring compressors that installs inside of the coil spring. Ecklers and the other websites sell it. I borrowed a Snap-on spring compressor from a Mechanic. The Snap-on spring compressor costs about $189, but is well designed and easy to use.
