Map Light Installation
Old Jul 25, 2006 | 09:15 PM
cnole's Avatar
cnole
3rd Gear
Default Map Light Installation
I just purchased a 75 and wanted to replace the map light under the rear view mirror. I can't figure out how to change the bulb with such a small space? Any suggestions? Thanks
Old Jul 25, 2006 | 10:33 PM
RMS73's Avatar
RMS73
remove the clear lense and the bulb and light assembly will pull out of the mirror housing.
Roger
Old Jul 26, 2006 | 10:24 AM
cnole's Avatar
cnole
3rd Gear
Roger- Thanks but I'm having trouble aligning the bulb in such a small area.
Old Jul 26, 2006 | 11:06 AM
GuinessGary's Avatar
GuinessGary
I just replaced my light bulb on my 76 this past Sunday. I couldn't get my fingers on the bulb either. I took my mirror off so I could see everything on the inside. First I removed clear lens from mirror. It pulled out from the light switch. Then I removed light switch assemby. Pinch it together at the center of the opening and pull out. The switch handle and the copper retaining mechanism should pull out together. Then remove the light from the retainer. I bought bulbs at Advance Auto, Sylvania 561, 2 pack for $2.48. I hope this helps. Gary
Old Jul 26, 2006 | 12:44 PM
cnole's Avatar
cnole
3rd Gear
Thanks Gary. I'll give that a try. Chris
Old Jul 26, 2006 | 06:20 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Is it hard to remove the clear lens? Mine has some black dots appearing in the lens....was thinking about changing it out.
Old Jul 27, 2006 | 01:58 PM
GuinessGary
No, it was not hard to remove the clear plastic lens, I used a very small flat screw drivers to pry it loose.
To Map Light Installation
