Angled Plugs work with Hookers?
Old Jul 25, 2006 | 11:21 PM
sperkins's Avatar
sperkins
Default Angled Plugs work with Hookers?
Will D-port angle plug heads work with Hooker side mount headers? I've installed the exhaust before, but on 'normal' heads.
Thanks.
SP
Old Jul 25, 2006 | 11:29 PM
slowup's Avatar
slowup
Wat kinda heads are u gettin..almost sounds like my edelbrock RPM's. And yea they work, just a lil tougher gettin to em'.
Old Jul 26, 2006 | 10:26 AM
Jack71's Avatar
Jack71
I have hooker comp headers on angle plug heads. One plug is wicked tight. I have to use shorty plugs and still have maybe a 1/2 inch clearance.
Old Jul 26, 2006 | 11:14 AM
sperkins's Avatar
sperkins
Thanks guys. What about D-port to header flange compatability?
Old Jul 26, 2006 | 02:08 PM
toocool80's Avatar
toocool80
On the hooker website there is no reference to d-port, but if it is a small block they will not fit angle plugs. However, if it is a big block then your in luck. Here is the link:
http://www.holley.com/types/Super_Comp_Sidemount.asp
pick your application then on the next page on the bottom put in year, make, and model and it will give you all of the footnotes for fit.
Good luck!
toocool 80
Old Jul 26, 2006 | 03:38 PM
sperkins's Avatar
sperkins
Thanks toocool80. Looks like this is what I'll need:
2224-3HKR
Super Competition Sidemount Header
62–82 Corvette: 265–400, Full Length Tube Size 1.875" x 46", Collector Size 4", Collector Length 10", Port Shape Rectangle, Hand Polished Stainless
It does not specify fitment on smallblock with angle plugs?
Old Jul 26, 2006 | 05:39 PM
MelWff's Avatar
MelWff
I installed Hooker side mounts on my 69 small block which has an early version of Chevy's angle plug heads. The interference problem is at the #2 cylinder and requires the use of a modified spark plug socket. I use a five sided socket that has had the hex end shortened. You then place an open end wrench on it. This is the reason why Hooker lists them as wont fit angle plug heads.
Old Jul 26, 2006 | 08:51 PM
nastee383's Avatar
nastee383
The "angle" is different depending on the particular brand of heads.
Old Jul 27, 2006 | 08:43 AM
sperkins's Avatar
sperkins
Thanks for the advice, but I have no freakin clue what you're trying to explain.
Old Jul 27, 2006 | 11:10 AM
MelWff's Avatar
MelWff
A normal spark plug socket is fully enclosed, hex shaped 6 sides, and requires you to slip the socket over the end of the plug. One of the sides is removed enabling you to slide the socket sideways over the plug since there is insufficient clearance to slip a normal socket over the end of the plug.
Old Jul 27, 2006 | 12:01 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
In most catalogs it says that they don't fit angle plug heads.
With shorty plugs and an extension between the spark plug and the wire boot it might fit.
Old Jul 27, 2006 | 12:11 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
What heads do you plan to run? I had no problems with the Sportsman II heads, but had to "massage" a tube on the passenger side for my AFR210's to work. The AFR's also raised the headers up so they are much tighter to the bottom of the frame than with the Sportsman II also.
Old Jul 27, 2006 | 12:52 PM
sperkins's Avatar
sperkins
Here is what I plan to run:
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 27, 2006 | 01:11 PM
Jack71's Avatar
Jack71
Here's a link to recent discussion on special tools for tight plugs...
http://forums.corvetteforum.com/show....php?t=1448240
To Angled Plugs work with Hookers?
