directionals blink fast
Old Jul 28, 2006 | 12:10 AM
ctrain22's Avatar
ctrain22
Default directionals blink fast
Can't figure this one out. When I turn on my directionals, they seem to blink normal for about three blinks, then gose fast and sporatic. I changed the flasher, but no difference. All the lights are working, just blnking wierd. Any suggestions?
This was happening before my stupid move on another post.
Old Jul 28, 2006 | 04:29 AM
kb2fzq's Avatar
kb2fzq
Does this happen in only on direction or both left and right? check your blinker lights grounds...
Old Jul 28, 2006 | 05:12 AM
Richieboy's Avatar
Richieboy
My 81 blinks slow at idle and faster as the rpm picks up. Is there something wrong or did GM just use a lame regulator design?
Maybe you have too much power to the signal system? Too big of fuse letting more voltage = faster blink?
Old Jul 28, 2006 | 05:14 AM
Bob Onit's Avatar
Bob Onit
Get yourself a Heavy duty flasher..... Problem solved
Old Jul 28, 2006 | 08:34 AM
pws69's Avatar
pws69
Utter nonsense!!!!!
Old Jul 28, 2006 | 08:57 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
mine do pretty much the same thing, i just live with it till i can get another flasher, you know there are two right?
Old Jul 28, 2006 | 08:58 AM
sweethence's Avatar
sweethence
Originally Posted by pws69
Utter nonsense!!!!!
poppycock and boulderdash you say ........
Old Jul 28, 2006 | 09:00 AM
pws69's Avatar
pws69
ya, ya, that's it!!!
Old Jul 28, 2006 | 10:46 AM
cchristo's Avatar
cchristo
aaargh
Yup, that's got to be it!
Seriously, I would probably just try a new flasher first.
Old Jul 28, 2006 | 01:13 PM
76stingracer's Avatar
76stingracer
Check all the bulbs. Could have a blown one or one is not making good contact in the socket.
Old Jul 28, 2006 | 05:39 PM
ctrain22's Avatar
ctrain22
Already replaced the flasher, twice in case one was defective. All heavy duty. The car wasn't even running, so alterrnator speed was not an issue. Grounds might be the problem. I will check them. Strange, they start normal for about 2 or three blinks, then go fast.
Old Jul 28, 2006 | 06:17 PM
depdep3's Avatar
depdep3
Check your turn signal fluid, it may be low. hmmmmmm
Old Jul 28, 2006 | 08:21 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Heavy duty bulbs vs standard bulbs WILL affect blinker speed. (Don't know which you're supposed to have on a 70 so you'll have to look that up). Check the bulbs front/rear AND side marker bulbs. Your side marker bulbs are in the blinker circuit as well. If they are old with dirty contacts this too will impact blinker speed. So get our there and clean/check those bulbs so you know what you're working with.
Old Jul 28, 2006 | 08:36 PM
SIXFOOTER's Avatar
SIXFOOTER
OK, blinker speed is controlled by the load on the flashers and the applied voltage. Thats why they Normally flash a bit faster at speed than they do at Idle. The wrong bulbs (to much current, high wattage) will cause them to flash fast. A trailer connected and light duty flashers will make them flash fast(to much load). A short will cause them to flash fast. A bad ground will not. Check all your bulbe for the correct number in the correct positions, Check for debris in the sockets (rust). Its there somewhere
Old Jul 28, 2006 | 09:56 PM
noonie's Avatar
noonie
Already replaced the flasher, twice in case one was defective. All heavy duty. The car wasn't even running....
Heavy duty electronic flashers are not prone to the "faster flashing" syndrome because they do not use the bi-metallic contact spring that is governed by current draw.
How do the 4 way hazards flash???
Old Jul 29, 2006 | 01:35 AM
Bob Onit's Avatar
Bob Onit
Sorry for the wrong advice
In all my days of owning GM cars the heavy duty flasher always cured the "fast blink" problem
Sorry........
Old Jul 29, 2006 | 02:37 AM
Rockn-Roll's Avatar
Rockn-Roll
He didn't say he noticed a leak, so how can it be low?
Seriously...you either have a bulb out or not getting good contact...as Hammerhead Fred suggested, or a ground wire may not be making good contact. Since the body is fiberglass then every bulb on the car has to have a grounded fixture...it's possible that one of the grounds needs some adjustment. Maybe turn the signal on so that it's blinking fast and then go around and jostle the wires for each bulb and see if you can get the speed to change.
It almost sounds like there's some current running from the tachometer to the flasher system.
To directionals blink fast
Old Jul 29, 2006 | 02:57 AM
Richieboy's Avatar
Richieboy
Utter nonsense!!!!!
Just a thought
Old Jul 29, 2006 | 03:27 AM
Bob Onit's Avatar
Bob Onit
Good question.....
Old Jul 29, 2006 | 06:27 AM
kb2fzq's Avatar
kb2fzq
Check your marker lites...make sure they are all lit with turn sigs on....
