directionals blink fast
Old Jul 30, 2006 | 12:51 AM
ctrain22's Avatar
ctrain22
Are you saying that the side markers blink with the directionals?
Old Jul 30, 2006 | 10:57 AM
pws69's Avatar
pws69
Originally Posted by ctrain22
Already replaced the flasher, twice in case one was defective. All heavy duty. The car wasn't even running, so alterrnator speed was not an issue. Grounds might be the problem. I will check them. Strange, they start normal for about 2 or three blinks, then go fast.
Did you change the correct flasher? Not trying to be a wise guy, just speaking from personal experience...
When I was putting mine together originally (it was a basket case), and finally got to the lights, I wasted too much time trying to fix a directional issue because I was changing the flasher on the fuse block - WRONG!! - it was on the passenger side just above the courtesy lamp!
Just a thought...
Old Jul 30, 2006 | 02:07 PM
Bob Onit's Avatar
Bob Onit
They do on a 73' and they alternate as well .... front/side front/side ect:
Old Jul 30, 2006 | 05:24 PM
ctrain22's Avatar
ctrain22
I have been changing the falsher on the fuse box. Didn't know there was another. I have to try that one. Thank goodness for this forum and you guys. It is great to be able to pick each other's brains like this.
Old Jul 31, 2006 | 07:19 PM
ctrain22's Avatar
ctrain22
Thank you PWS. That was it. Put the new flasher in the correct socket and BINGO......it works fine now. Am I the only one that didn't know that??
Old Aug 1, 2006 | 07:33 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
That is why I asked if you knew there were two of them
Glad your all set now
tim
Old Aug 1, 2006 | 08:15 PM
ctrain22's Avatar
ctrain22
Just like reading instructions, didn't even see that you asked that.
All is well now, so thank all for the help
Old Aug 2, 2006 | 07:43 AM
sweethence's Avatar
sweethence
great, now ill go get mine
