halfshaft u joint question
Old Jul 31, 2006 | 12:18 PM
mr mctavish's Avatar
mr mctavish
Default halfshaft u joint question
Could someone tell me what size/type bolt this is ?
wheel bearing went.
and also can the wheel bearing assembly be taken out/ replaced, without taking the T.A. out? --- thanks
Old Jul 31, 2006 | 01:14 PM
TFitz's Avatar
TFitz
the bolt takes a 9/16'' wrench, it is fine thread,1/2'' threaded diam.
you will need to take out the trailing arm since there will be the need to press out the old bearing and you will need special tools to re-install the bearings. you can buy the tools or rent them from corvette america I think. The best bet is to remove the trailing arm and take it to a corvette shop to have it set up.
Old Jul 31, 2006 | 01:21 PM
big_G's Avatar
big_G
The bolt circled is an " inverted torx", size E-10.
Old Jul 31, 2006 | 01:22 PM
Steve439's Avatar
Steve439
1/2 sounds pretty big... I don't know - I don't have that type.
You don't absolutely have to take the arm out, but it looks like it could use a good cleaning and paint job...
Old Jul 31, 2006 | 01:53 PM
mr mctavish
Thanks big g thats exactly what i needed to know.
the bearing assembly is pressed into the trailing arm? I thought the bearing get pressed into the assembly - witch i will get as a unit.
Old Jul 31, 2006 | 02:20 PM
Steve439's Avatar
Steve439
You're correct - the spindle and bearings are contained in the bearing support. That's part of the assembly you can buy. Here are the instructions from Van Steel fro removing the assembly:
http://www.vansteel.com/index.cfm?fu...BearingRemoval
Old Jul 31, 2006 | 03:10 PM
mr mctavish
steve 439 -----thanks
Old Jul 31, 2006 | 03:26 PM
theoUK's Avatar
theoUK
Although one of those "inverted torx" type sockets might fit on there, it's actually a 12-point, 1/4 inch socket that you need. I can tell you this for sure, as I've only just finished doing this myself. I'm not sure off the top of my head if the torx bits have 12 points, have a feeling not. You need to do everything you can to avoid rounding these little buggers off, so I'd stick with the 12-point to be honest. Half inch ratchet and a good six inch, (or even longer) extension makes it easy to go at them straight.
The bearing assy is a tight fit in the trailing arm, not helped by 25 years of rust. I did mine on the bench with the T/A off, but they can be seperated from the T/A whilst it's still on the car, if that's what you prefer.
Theo
Old Jul 31, 2006 | 03:31 PM
Steve439's Avatar
Steve439
You're welcome!
One thing worth mentioning - I'd really soak the four nuts that hold the assembly to the trailing arm. I use PB Blaster. If one of those bolts get messed up it'll be a PITA to replace it on the car. They're pressed into the arm and kinda hard to get to.
Old Jul 31, 2006 | 04:23 PM
mr mctavish
I was trying to avoid clamping,jacking and releasing spring. we all know that,and as we all know, 'there is no easy way".
yesterday those u joint bolts stopped me cold. everything I had was a sloppy fit-- so their soaking for today. tomorro is tool hunt day.
Does van steel have a local over the counter store?
My son was driving it at the time, noticed the problem and was able to get it to his boss'es house ---- it's stuck in his driveway. so...... i have to fix soon.
Old Jul 31, 2006 | 04:33 PM
theoUK's Avatar
theoUK
It's not really a "special" socket as such, so should be pretty easy to come by. If you've got/can get a normal half-inch drive, 12-point socket set that goes down to quarter inch, you're set.
Old Jul 31, 2006 | 04:42 PM
Steve439's Avatar
Steve439
They're in Clearwater so I think you'd have to get it to them.
I'd call and ask for Dan - he's a good guy and active on the forum.
He might be able to send you one and have you send the core later.
big_G's Avatar
big_G
Theo
Some late C-3's have 12 point 1/4 inch bolts, the pic.looks like a 6 point torx bolt.
Old Jul 31, 2006 | 06:22 PM
mr mctavish
it appears to be inverted torx -- the head seems to taper
Old Jul 31, 2006 | 08:05 PM
moosie982's Avatar
moosie982
Theo
I think that you are correct because that is what size and type wrench I needed for my '80. Wound up breaking two wrench's tho,,,Peace,,,Moosie
Old Aug 1, 2006 | 04:22 AM
theoUK's Avatar
theoUK
As someone else confirmed above, the 12 point 1/4 inch bolts are the stock ones, they came in at some point after the swap from U-bolts to straps as the UJ holding method. But it's totally feasible that someone's put torx bolts in after the fact. I guess you just need to make totally sure you're using the right one of those two socket options, because the last thing you want to do is round them off!
Good luck with it.
Old Aug 1, 2006 | 06:28 AM
Bob Onit's Avatar
Bob Onit
So THATS what causes the rear wheels to go out of whack!
I always wondered what caused this problem.
That has to make a hell of a racket.
For ages there was a white Stingray around my area with both rear wheels doing just what yours is doing
I used to see it almost daily
It was almost as ratty as the woman that drove it..drove it year round too, snow rain ect.
I do remember the LS-4 tag on the hood so it had to be a 1974....no chrome
Sure wish I could run into her again as that would be a great parts car............ hmm.... havnt seen her or the car in a few months
Old Aug 1, 2006 | 09:56 AM
mr mctavish
that sounds like a camber/strut rod problem.
I thought I had heard the swissshing sound of a scraping bearing just once, over the sound of the flowmasters and the tops being off. but i din,t hear anything wrong after that. It went quick. The right side went 2 years ago..... I had it done at a shop and said go ahead and do both sides.. mech said nah... the right side looks good it should last for years.. he was very buesy at the time.
To halfshaft u joint question
