TPI conversion info request.
Old Aug 1, 2006 | 08:21 PM
DR.Jay's Avatar
DR.Jay
Default TPI conversion info request.
I saved alot of the links, and info that you'all posted about converting to Tuned Port Injection when I had asked in the past. Well now it is time to start the newest upgrade. I have been able to get the doner TPI system up and running while it is in the doner Camaro. Can we say Varnish in the fuel tank.
What I am asking for is any other reference, tips, and tricks that you can share with me, and any others that may be planing this same conversion.
Thanks DR. Jay
Old Aug 1, 2006 | 08:42 PM
PatsLs1vette's Avatar
PatsLs1vette
Well i had already did mine and then changed to a ls1 ,but i just finished putting my old motor and tpi into a 80 vette for forum member bcpockets.JUst ask what you need to know and will answer it.
Heres a good website with alot of info.
http://www.chevythunder.com/
also heres my old site with my tpi
http://www.angelfire.com/nj4/patsvette/
Old Aug 1, 2006 | 08:55 PM
DR.Jay's Avatar
DR.Jay
Thanks Pat. I have saved your old site to a file in favorites as a referance. What is your best suggestion for a fuel pump? In tank or along the frame rail? I remember posts about fuel starvation.
Old Aug 1, 2006 | 09:08 PM
big_G's Avatar
big_G
I like the pump outside the tank for maintenance, but good in-tank pumps are available. My only other suggestion is that you invest in new injectors, not used. They have come down in price, and only about 2X the cost of cleaning them.
Old Aug 1, 2006 | 09:18 PM
markdtn's Avatar
markdtn
You have a unit
First you have to determine whether you want mass air flow or speed density. The C3 is more conducive to speed-density due to space issues. Mass-air flow is easier to make engine changes without PROM changes. If you are technically proficient enough to make a Camaro harness work they can be bought for $100 or less. I have been told that you can also use a 3.1 Corsica or Cavailier harness with a little work, it uses the same 7730 Speed-Density ECM. Aftermarket harnesses range from about $300 for Painless to $500 for Howell to $700 for Street and Performance. Howell makes a great harness, but for a Tuned Port they do not make one that will control the converter lockup on a 200R4/700R4/4L60 transmission. If you are running a manual or non-overdrive-automatic transmission I highly recommend them. I have heard great things about Street and Performance harness, but do not have first hand experience with them. I also have a Fuel Injection Specialties (FIS) harness and it is OK. The ECM can be had used for $10-50. A good external fuel pump will cost at least $100. I use an 88 Ford Truck external pump, $114 from CarQuest, made in Texas by Airtech. If you have a 78-82 you can use your fuel tank with an 82 sending unit and a TPI pump. An aftermarket PROM with VATS and Emissions codes removed will be $100-200 depending on source and complexity. You will have to add an oxygen sensor to your exhaust, $20 for the sensor, $5 for the weld-in bung, and say $25 for an exhaust shop to weld it in if you can’t. Some harnesses use VSS and some do not. An auxiliary VSS sensor is around $75. To install a TPI I say figure at least $800 plus the TPI unit and whatever repairs are necessary to bring it up to useable status. I have TPI/700R4 in my 69 Corvette (Howell harness) and an 83 Pickup (FIS harness) and I love it. Starts good, great torque, good fuel mileage, easy to swap onto stock engines (although both of mine are complete engines out of 90/91 ‘Vettes).
Differences in years
All Corvette TPI intake manifolds work with the older (through 86) iron heads and the factory aluminum heads through 91. F-body TPI intakes use the upright center bolts on 87-92 and thus fit all 87-95 iron heads (non LT1). Either can be swapped to fit the other with some drilling. F-body has the fuel lines come out on the drivers side and has a central port for EGR. Corvette has fuel lines that come out on the passenger side and has an external port for EGR. Corvette fuel rails fit F-body intakes and vise-versa. The runners are all the same through the years, but the LH runner has a hole for a 9th injector in the 85-88 runners. This can be plugged off if you get a nice LH runner and don’t want the 9th injector or decide to run speed-density. The plenums all physically interchange, but 90-92 have an extra vacuum port for the MAP sensor used with the speed-density computers and wiring. 89 is an odd year, it is mass-air flow but without the 9th injector. 89 up throttle bodies can be used on all years, but a 85-88 throttle body requires a ½” hole be drilled in the front of a 89-92 Plenum for idle air. 89-92 Throttle bodies have a bit more desirable cable attachment. The cable attaches around a circular linkage which has a smoother actuation than the straight linkage on the 85-88. The Corvettes have an aluminum plenum extension over the distributor, the F-body extensions are plastic. The Corvettes use an HEI coil-in-cap distributor for 85-91 (Delco 1103680). 85-86 F-body also used a big-cap distributor. 87-92 F-Body used a small cap distributor with an external coil (Delco 1103479). This same distributor is used in the 87-95 5.0/5.7/7.4 TBI injected trucks. The F-body intake gets it's exhaust for EGR from the center passages in the heads like most SB Chevys. A Corvette intake gets it's EGR exhaust from the RH exhaust manifold/header through a flex-tube to an opening near the distributor-no center passages in the intake. If you are required to keep EGR and you have a Corvette intake, I recommend getting the C4 exhaust manifolds. They are like mini-headers, and have a 2 1/2" outlet. I have them on my 69 and like them.
As far as a throttle cable to use, on my Vette, I used a TPI Corvette cable, 1990 I think (about $20 new GM) but you have to cut the end off inside the car and use a hood-release-cable end (Corvette Central 342138 "cable stop") to get it the correct cable length (the housing is OK). You must use a cable from the type car your throttle body came from if you want to have a chance of not cutting it. Again, 85-88 use a straight pull, while 89-92 have a circular attachment for more smooth actuation and so the inner cable is longer. On my 83 truck I used a TPI F-Body cable and it was OK, but I had to coil it up into a loop in the engine compartment because the housing was so long. I also TPI'd a 72 Chevy truck and used a 90 350 TBI truck cable for it. It was 1/2" short outside if anything, but I was pretty pleased with it all told-I didn't have to shorten it. In a Vette it might be about right. In all vehicles I've done you need a die grinder to square the firewall hole off a bit. All vehicles I've done used the late throttle-body.
Why to get it
If all you want is around 300 hp there is no reason to spend a pile of money on a crate motor. The basic $1200 4-bolt Goodwrench 350 with an aluminum intake and a Holley will put out power in that neighborhood. Chevy High Performance (I think) did a series of articles with one of those a few years back and with decent exhaust should get you in that range.
I would look into a TPI. They start immediately in winter, have great vacuum, and will get great mileage. I can open the headlights and the wiper door at the same time with no hesitation at all-solid wooomp. With 3.70 gears (and a 700R4 overdrive) I get 18mpg city and 22+ highway. With 3.55 or 3.36 it would be even better. You can probably find a used Corvette TPI engine for $1000 and with an $800 harness/computer/fuel pump you would be set. On a 78-82 you can use the stock fuel tank with an 82 sending unit and TPI pump and be in better shape than 68-77 with an external pump. With the Vette TPI you would have aluminum heads that would remove weight. Even with an F-body iron-head TPI 350 it will be less weight than a stock intake. It will bolt up to everything in your car, use stock accessories, use your transmission, and the visual appeal is awesome. Don't be afraid of fuel injection, it really works.
As far as websites see:
www.corvettefaq.com for conversions or more TPI info at www.fuelinjection.com
Old Aug 1, 2006 | 09:23 PM
DR.Jay's Avatar
DR.Jay
I had to get the doner engine running on injector cleaner plumbed through the test port on the rail because the bad fuel that was in the tank killed the fuel pump. New injectors are cheap insurance for down the road.
Thanks Big G
Old Aug 1, 2006 | 09:45 PM
big_G's Avatar
big_G
Yw, G/L with the conversion! Bring it by when you get 'er done...
Old Aug 1, 2006 | 09:57 PM
PatsLs1vette
I used a walbro 255 intank pump,frame mounted would be easier like mark said,i used 24 lb motorsport injectors also cause i went with a bigger cam.also heres how i did bcpockets mass air flow setup it has a vortex air filter bringing air in from the bottom.Heres bobs(bcpockets motor,i painted the runners and valve cover inserts in pearl white since were painting the car pearl white in the winter.As far as the 80 vette we used a 82 sending unit and put a 89 vette replacement fuel pump in it,i drove it as low as 3 gallons and it runs out .
Old Aug 1, 2006 | 10:40 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Been there too.
Old Aug 2, 2006 | 12:23 PM
DR.Jay's Avatar
DR.Jay
Pat, Budman, what throttle cables did you use? Did you have all the emissions parameters in place or did you get a custom prom?
Old Aug 2, 2006 | 12:57 PM
PatsLs1vette
I used one from a 87 trans am,very little modifying to do to firewall and gas pedal.I had my prom custom programmed ,emissions deleted,no vats,bigger injectors etc...
Old Aug 2, 2006 | 01:42 PM
DR.Jay's Avatar
DR.Jay
Good. I will keep the cable from the Camaro, and just make the mods nessassary to make it work. Who did you get your custom prom from?
It's going to be so much easier with a whole donor car to work with, and not a basket case of scavenged parts.
Old Aug 2, 2006 | 03:00 PM
PatsLs1vette
I had -=jeff=- thats his forum name here on the forum do mine.
Old Aug 3, 2006 | 10:26 PM
markdtn's Avatar
markdtn
I would use a C4 cable or TBI truck cable, the F-body cable is very long. I would find an 82 sending unit and use an intank fuel pump for your 78 too.
To TPI conversion info request.
