frame cut
Old Aug 9, 2006 | 10:35 AM
Joe45's Avatar
Joe45
Default frame cut
Will be getting ready to do a frame graft. Any advise on proper cutting tool to use? Sawz all,plasma cutter or?
Old Aug 9, 2006 | 11:29 AM
johns73's Avatar
johns73
I used a sawzall before i had a plasma cutter, Either will work.
Old Aug 9, 2006 | 01:08 PM
wills670's Avatar
wills670
A grinder with a cut off wheel works good.
Old Aug 9, 2006 | 02:01 PM
Boofers's Avatar
Boofers
My friend built his 73 camaro with one tool above all others, the mighty grinder.
Old Aug 9, 2006 | 02:51 PM
fl_rider's Avatar
fl_rider
Default Dont forget...
Measure it with a micrometer
Mark it with chalk
Cut it with an axe
Old Aug 9, 2006 | 03:16 PM
Twin_Turbo's Avatar
Twin_Turbo
Use a grinder with 1mm cutting blades and if you can do a V cut, slide in a close fitting section and rose weld it inside, then slide the new section on, do some rose welds there also and lay a nice bead in the V groove where the 2 meet. This way you have more weld area for strength.
Old Aug 9, 2006 | 03:21 PM
bashcraft's Avatar
bashcraft
If you can get a plasma cutter, by all means use that.
Old Aug 10, 2006 | 06:22 AM
Joe45's Avatar
Joe45
Twin Turbo, Please excuse my ignorance..what is a rose weld? Tried looking it u with no luck. A local shop will be doing the welding I am just trying to understand this stuff (from people who have done it)before it goes in so I know what I want done. Thanks
Joe
Old Aug 10, 2006 | 08:22 AM
Twin_Turbo's Avatar
Twin_Turbo
You drill a hole in the frame and slide a smaller OD square section inside, then you weld in the hole. It's also referred to as a plug weld :
Old Aug 10, 2006 | 10:34 AM
68 NJConv 454's Avatar
68 NJConv 454
Interesting, learn something new each day!
Old Aug 10, 2006 | 10:36 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Heyy TT, when are you crossing the pond to work on my car? Heavan knows I need help......
Old Aug 10, 2006 | 05:08 PM
Twin_Turbo's Avatar
Twin_Turbo
<- for hire
Old Aug 10, 2006 | 08:15 PM
wills670's Avatar
wills670
I think this is what tt is talking about. I done the same exact repair to my frame.
[IMG][/IMG]
Old Aug 11, 2006 | 06:43 AM
Twin_Turbo's Avatar
Twin_Turbo
Yes, that's what I mean. I assume you have some kind of beam or section of U channels inside where you grafted the 2 together? Nice work BTW!!!
Old Aug 11, 2006 | 08:33 AM
wills670's Avatar
wills670
Yes I do. I cut about 8 inches from the old frame. Then I split it open and sand blasted the parts and cut them down to fit the inside of the frame. Thanks for the compliment.
Old Aug 13, 2006 | 04:53 PM
Joe45's Avatar
Joe45
TT & Wills 670
Your feedback is exactly what I have been looking for. The photos help alot and what Wills has done is what I will be doing. Most likely in the same location. Any further advice on what to look for would be appreciated. Wills 670.. I see you had a jig system set up.. was this to hold the frame and how did you cut yours? As well as did you mig weld? Any thing that can be provided would be greatly appreciated.
Best regards,
Joe 45
Old Aug 13, 2006 | 06:50 PM
wills670's Avatar
wills670
I used the jig to hold the frame still. The channel was leveled and then I used concrete fasteners to bolt it to the floor. I took my time and used a sazall to cut the frame but a cut off wheel on a grinder would work better.
I used some alum. strips about 4 inches wide to make patterns for my cuts. That way both cuts on each frame would be the same.
I used a mig welder for my welds and v groved the butt ends and drilled 1/2 inch holes for the plug welds.
Here is another pic. of the jig. If you will notice I made the rear part where it will unbolt from the frame and jig. If you don't do it this way the frame will not slide over the inserts on the inside of the frame. You need to make the inserts tight fitting on the inside if the frame. Also take your time welding it you do not want to get it too hot it can warp.
[IMG][/IMG]
Old Aug 13, 2006 | 10:33 PM
BB72's Avatar
BB72
Default Frame cut
This might sound like overkill...but my friend in PA, who owns a Corvette shop there, Gee's Corvettes, bought a gas powered cut off saw when I was with him one time. You know, the ones with the 10 to 12 inch discs on them you see construction workers cutting ashphalt with. He said it's awesome to get a really straight cut on a frame. Makes sense to me.
Old Aug 19, 2006 | 04:58 PM
Joe45's Avatar
Joe45
Yet another question... I have received my donor front frame 1/2. Should I have this section sent to a frame shop to chech for straightness prior to the grafting process? My mind says yes just to ensure that it is true prior to trimming and welding to the back 1/2. My concern is if I don't my measurements will be off. Advise please.
thanks
Joe
To frame cut
