VBP front mono bar setting
Old Aug 9, 2006 | 12:21 PM
Highhat's Avatar
Highhat
Default VBP front mono bar setting
Below is a photo of my mono bar.
Anyone know which setting (of the 4 holes) is better for racing?
Old Aug 9, 2006 | 12:36 PM
Meh's Avatar
Meh
Farther outside is stiffer. What is better will depend on what type of racing you're doing and also the rest of your setup, as there is no preset "best" setting. If there was, racing would be a lot easier.
On a side note, I don't have the front setup, just the back, but aren't the mounts supposed to be mounted in such a way that the holes are horizontal? Sorry, just don't recall seeing them mounted at an angle like that.
Old Aug 9, 2006 | 12:41 PM
Highhat's Avatar
Highhat
Thanks. I dont know how it's supposed to be installed, this was on the car when I bought it some years ago.
Old Aug 9, 2006 | 12:51 PM
iNdigo's Avatar
iNdigo
Yeah something looks wrong with those mounts for the monoleaf. I wonder if the brackets were accidentally switched L/R?
Old Aug 9, 2006 | 01:04 PM
Highhat's Avatar
Highhat
Maybe VB&P can weigh in.
Old Aug 9, 2006 | 01:05 PM
68 NJConv 454's Avatar
68 NJConv 454
That setup looks very wrong as I am in the process of installing the front leaf now. Should definitely be parallel to the leaf spring. Otherwise if you went to the outermost setting the distance b/w the spring and the frame/spindle would change. I don't think you would feel the desired result in stiffness if adjusted to the outermost setting b/c the ride height change would have to be adjusted in the bolts that attached the end of the leaf spring to the a-arm near the spindle. Very weird.
Here's the settings from VB&P:
Inner most hole: soft suspension
3rd hole to the outside: street & race
4th hole (outermost towards wheels): strictly race.
Good luck
Old Aug 9, 2006 | 01:56 PM
Smooth72's Avatar
Smooth72
I hope this helps. It looks like the A arm are on backwards.
Old Aug 9, 2006 | 02:48 PM
68 NJConv 454
I agree, definitely looks like the left and right got switched.
You can see the 90 degree part of the bracket is on the wrong side. Should be outboard.
How this has worked safely thus far means someone upstairs has a special liking to this car.
Consult VBP to make things right.
Old Aug 9, 2006 | 03:49 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Shouldn't be too hard to straighten out, unless they welded the mounts on.
Old Aug 9, 2006 | 05:37 PM
Highhat's Avatar
Highhat
That helps immensely. Many thanks.
Old Aug 9, 2006 | 09:52 PM
1ARACE's Avatar
1ARACE
I just got the VBP suspenion package in, how do you guys like it? Handle/drive better? Is it pretty easy to adjust, about how long does it take you? Just curious, but has anyone ever said anything to you about the suspension not being original or any crap like that after checking your vette out?
Old Aug 9, 2006 | 10:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If someone says that, just tell them that they're free to leave theirs stock and leave yours alone.
Old Aug 9, 2006 | 10:50 PM
rosslato's Avatar
rosslato
i love the way it rides and handles now. very simple to adjust. i blasted all the parts and por-15'd em and topcoated em and took the frame to bare metal and por-15'd and topcoated and repainted the engine w/por-15 eng paint. it took me about 2 months cuz i also redid the engine bay. haven't had any negative comments but then again one look at my exterior and u know you're not looking at stock.
Old Aug 10, 2006 | 02:08 AM
Z-man's Avatar
Z-man
It looks like your setup is in backwards! It also doesn't look like you can change bolt holes either. Your whole car will probably handle better just by getting the parts in correctly...
Old Aug 10, 2006 | 12:15 PM
iNdigo's Avatar
iNdigo
All the reference photos contributed are for the boxed A-arm version, you have the monospring setup for standard A-arms, and it looks like the brackets were swapped during assembly R/L. It doens't look like your ball joint cups are upside down (i don't think the car would be driveable if that were the case) but the A-arm mount shafts are definitely switched. You need to get those A-arms off the shafts, and swap them back.
Old Aug 10, 2006 | 01:26 PM
Smooth72's Avatar
Smooth72
Here is another angle. Can not tell you about the ride still rebuilding. Still in this condition. At least I have this to drive and keep the 72 company.
Old Aug 10, 2006 | 01:31 PM
Smooth72's Avatar
Smooth72
Stock, what is that?... that is what it is untill you get it home and start making it your own On my C6 I had the exhaust wheels and grill before it came in, it help that it was aroung Chritmas.
To VBP front mono bar setting
Old Aug 10, 2006 | 02:42 PM
68 NJConv 454
Smooth72, where'd you get that front end with those fenders? I like those grills cut into the inner fenders. That will look real sweet painted with an L88 or muscle hood.
Old Aug 10, 2006 | 03:29 PM
Kalway's Avatar
Kalway
Curious, how hard is it to do the monoleaf conversion on the front? I'd imagine it's not super hard, but what would be a time estimate of how long it'd take to do?
Old Aug 10, 2006 | 04:51 PM
rosslato's Avatar
rosslato
if you're just doing the swap and no cleaning i'd say easily within 8 hrs start to finish. u will also need to get an alignment
