How do I remove the gauge cluster?
Old Aug 9, 2006 | 05:31 PM
pdege's Avatar
pdege
Default How do I remove the gauge cluster?
The goal is to install a bulb in the check engine light that was removed years ago. The 4 screws holding the cluster are out and the bottom is hitting the AC control box. Center console loose but can't move it enough to get the cluster out. What little gremlins are holding these pieces in???
.........or should I just pull out my hammer assortment!
Old Aug 9, 2006 | 06:49 PM
marshrat99's Avatar
marshrat99
If my memory servers me correctly, on my 79 there are two screws on top next to the A/C vents, two along the sides, and two underneath that you'll have to reach from underneath and just behind the front of the console. These last two are probably what's holding you back.
Old Aug 9, 2006 | 11:04 PM
icanfixitforyou's Avatar
icanfixitforyou
Once all of the screws are out, tilt the top of the center gauge console out towards you, then reach around back and remove the center wiring connector from the circuit board, there are two tabs, one at top, one at bottom that you have to squeeze together to get the connector out.
Old Aug 10, 2006 | 12:05 AM
79 Bullet's Avatar
79 Bullet
on my 79 I have to remove the side carpeted panel because there are two screws that hold the gauge cluster to the shifter panel. They screw upwards. Don't force it it will break!
Old Aug 10, 2006 | 12:09 AM
gmviso's Avatar
gmviso
If your '79 is similar enough to my '77 you might just have to remove the side panel from the center floor console and be able to reach the bulb. It is in a socket which when turned about a quarter turn ccw both the socket and bulb come out. Good luck.
Old Aug 10, 2006 | 08:09 AM
Wuttin's Avatar
Wuttin
Bingo...leave them out if you think you'll be going back in to replace the rest of the bulbs...you can get along without them
Old Aug 11, 2006 | 08:19 AM
JustForFun's Avatar
JustForFun
why would a 79 have a check engine light. He would have to have an 81 or 82 wouldnt he?
To How do I remove the gauge cluster?
