Bouncing Headlights
Old Sep 6, 2001 | 10:52 PM
Jvette73's Avatar
Jvette73
Default Bouncing Headlights
Im not talkin about boobies here :lol: Im talkin bout my pop up lights on my 73 shark. Driving at night and hitting road bumps and whatnot, I see my headlights bouncing and vibrating. I know its with the pop ups ,but is there a way to secure these things stable while still mantaining proper function? Do I have a worn part or loose bushing or something?
Old Sep 6, 2001 | 11:19 PM
sb69coupe's Avatar
sb69coupe
Default Re: Bouncing Headlights (Jvette73)
Probably worn bushings on the pivot shafts for the headlight doors. A royal PITA to get at them, since you have to remove the entire headlight door. I've just learned to live with it ;)
Shannon
Old Sep 7, 2001 | 12:03 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Bouncing Headlights (sb69coupe)
Yep, it is a pain in the ..... I recommend changing them before a new paint job. You are bound to scratch something getting them in.
Old Sep 7, 2001 | 12:36 AM
SuperFast80's Avatar
SuperFast80
I have the same problem on the driver's side. After sizing up the job, I have chosen to ignore it. :crazy: :crazy:
Old Sep 7, 2001 | 12:32 PM
Alwyn678's Avatar
Alwyn678
Default Re: Bouncing Headlights (SuperFast80)
I have the same problem.....I just learned to endoy the light show.. :D
Old Sep 7, 2001 | 08:33 PM
Cajun99's Avatar
Cajun99
If it's not your bushings there is also a metal rod with an adjusting nut at the back of the assembly. When the lights open the nut on this rod hits a stop plate and the nut determines, to a degree, how high the lights pop up. From what I can tell it also helps in keeping your lights tight up against the stop so they don't jiggle up and down.
Mine jiggled when I first got the car and also rattled from not holding the light assembly tight against the stops. All I did was adjust the nut to the point where it was tight against the stop without binding the light to stop the wiggle. To get rid of the rattle I put a thin layer of GE silicone on the nut face and the area that it contacted the stop and let it dry (the lights were in the down position to do this of course). Voila...no more jiggles and no more rattling. My bushings were ok. :cheers:
[Modified by Cajun75, 6:34 PM 9/7/2001]
Old Sep 7, 2001 | 08:42 PM
jerryp58's Avatar
jerryp58
Default Re: Bouncing Headlights (Cajun75)
I'm with Cajun75 on this one.
My headlights were rock solid until I pulled the actuators to replace the seals. After I did some adjusting :smash: , my headlights would bounce & jiggle :rolleyes: .
The nice thing about trying to adjust the headlights is, it's FREE :D If it doesn't work, you can always check the bushings later.
Old Sep 7, 2001 | 10:23 PM
Jvette73's Avatar
Jvette73
Cajun75, Thats sounds like its worth checkin. May not be hard to fix after all. Thanks man.
Old Sep 8, 2001 | 04:18 AM
Cajun99's Avatar
Cajun99
Cool!
Whether it's the bushings or the other adjustments I hope ya'll get your lights working right!! Good Luck :cheers:
Old Sep 8, 2001 | 12:20 PM
theandies's Avatar
theandies
Get an Assembly Instruction Manual for your year. There is a headlight adjustment proceture in there. There is an overlock the the rod goes to and will lock your headlights in the up position. If adjusted properly, they shouldn't bounce unless a piviot bushing is worn out.
John
To Bouncing Headlights
