engine woes
Old Aug 10, 2006 | 09:00 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default engine woes
ok im going crazy depending on what path i should take. As we all know i got the bad end of the deal on my motor build using crap somg heads and rpm cam . Well I was planning on using some vortec heads upgraded for more lift with a comp xe262 cam and an air gap intake. Well I have been pondering the idea of a crate motor. To do the top end pakage im right at about 2500 bucks give or take a few this is using the stock bottom end with 4 valve reilfe pistons that have a lot of carbon build up for a rebuilt motor with less than 1000 miles on it. I fiqure for a few bucks more i can get a motor i know was built well and comes with a 2 year 12,000 mile warranty. Well I am looking at this crate motor from Derebery Performance. Here are the specs
350 ci 400 HP 430 TQ $2,995.00
-Balanced Dynamically
-9.5:1 Compression
-6000 RPM Limiter
-Hyperutectic Coated Pistons
-Hyd, Roller Camshaft 218/228 @.050 with .502/.502 lift
-Vortec Hand Ported Cylinder Heads
-Dual Plane Air Gap Intake Manifold
Idle
link to website http://www.dpmpower.us/smallblock.htm third one on the page.
So my thing is would you go for the crate motor or just do the top end and cam swap on my current motor that was built by bubba.
Thanks in advance for the help.
Old Aug 10, 2006 | 09:18 PM
Little Mouse's Avatar
Little Mouse
For $3,842.95 summit price the GM ZZ4 comes all brand new
aluminum heads. Add carb, plug wires, plugs and go.
Old Aug 10, 2006 | 09:23 PM
Silver00V6Camaro
If you look at the website i listed thats basically all you have to do to their motor. I already have a new accel hei so i just have to get plugs carb.
Old Aug 10, 2006 | 09:38 PM
Little Mouse
they may have a good motor makes a litlle more power cost is
around $900.00 less but the GM is an all new motor, not a rebuild
of old block crank and heads. the alumunum heads would be nice.
Old Aug 11, 2006 | 02:01 PM
Silver00V6Camaro
well i emailed them and this is what they sent me.
The Engine comes with a chrome oil pan, timing cover, valve covers and polished intake. The stock converter would be fine, but I would base an upgrade on what you plan to use the car for. The dyno sheet is attached. We do have carburetor and ignition options available.
Engine Specifications:
·Horsepower- 400+
·Torque- 400+ ft/lbs
·Compression ratio- 9.5:1
·Dyno-tested: Yes, includes harmonic balancer and flexplate
·Dyno sheet: Included with engine's output
·Vacuum produced: 12hg @ 800RPM
·Recommended fuel- 92 octane
·Max recommended RPM- 6000
·Block- Seasoned 4-bolt iron
·Crankshaft- Nodular iron
·Pistons- Hypereutectic
·Connecting rods- Powdered metal
·Camshaft- Hydraulic roller
·Valve lift:.520"
·Duration @ .050" (int/exh): 218deg/228deg
·Rocker arms- 1.6:1 ratio
·Cylinder heads- Ported Vortec
·Valves- Stainless steel 2.02 int/1.60 exh
·Valve springs: Heavy duty
·Bore x Stroke- 4.030" x 3.48"
·Intake manifold- Dual-plane aluminum
·Oil pan, timing cover, valve covers included
·Engine fasteners: High tensile strength
·Warranty- 12 month/12,000 mi
Old Aug 11, 2006 | 02:15 PM
Xakk's Avatar
Xakk
That looks like the same engine that Year One sells
http://www.yearone.com/serverfiles/f...ain2.asp?cat=0
Old Aug 11, 2006 | 02:17 PM
Silver00V6Camaro
it is derebery performace builds yearone's engines. So do you think its a good deal?
Old Aug 11, 2006 | 03:29 PM
dgruenke's Avatar
dgruenke
I don't know where you are going to find that much power for that price. Seems like a good deal to me.
Old Aug 13, 2006 | 11:23 PM
Silver00V6Camaro
ttt what is a good carb for this motor. Right now I have a 600 cfm holley thats a single pumper. I am thinking a 670 street avenger
Old Aug 13, 2006 | 11:29 PM
Silver00V6Camaro
Old Aug 15, 2006 | 07:48 PM
Silver00V6Camaro
ttt anyone Carb advice on this motor whats a good one will my current 600 4160 work
Old Aug 15, 2006 | 09:22 PM
Little Mouse
to feed 400 hp 770 street avenger. 750/780 cfm vacuum carbs and dual plane manifold on 302/327/350s. Dual plane manifolds work well with a bigger carb.
Old Aug 15, 2006 | 10:10 PM
mandm1200's Avatar
mandm1200
$2500 for the top end seems a little steep. Scoggins Dickey sells an upgraded Vortec package for $950 including new bolts and gaskets. Add to that $170 for a new cam kit and $xxx for new valve covers. I'm not sure if the XE262 cam would require extra lift from stock Vortecs. The XE268 would need the springs/retainers changed. Swapping heads is not that big of a deal, should take about a day or two if not in a big rush. Going to a Vortec package will require a little modifications on items like throttle brackets. Whether you go with a complete package or not, there are alsway the little things that pop up.
http://www.sdpc2000.com/catalog/2172...former-RPM.htm
Old Aug 15, 2006 | 10:13 PM
Silver00V6Camaro
was this for my post. this is a crate motor i am buying i said to hell with what the rednecks put in that car. Im just gonna buy a new motor. Plus this is a roller motor not a top end package.
Old Aug 15, 2006 | 10:45 PM
Vettkeeper's Avatar
Vettkeeper
I just bought this same motor tonight from Yearone. Two to three week delivery time frame. This motor was dyno’d @ 400+ with a 750 CFM carb. As for your comment about rednecks, who do think started all this horsepower stuff? We maybe dumb, but we ain’t stupid!!!
Old Aug 15, 2006 | 10:50 PM
Silver00V6Camaro
Take no offense to the redneck remark. I agree I am a redneck but atleast i have enough know how to know what works. The guys that built my motor where just dumb they did not know how to match everything up they thought that just because they put a big cam in and it loped really good it had 400hp what they did not know was that 882 heads are crap and thought they were a good performance head. Basically they thought that thoses heads and factory pistons gave me 10.5 compression thats what they told me the motor had because they had my heads supposedly surfaced to a 64cc. Yeah thats a lot of metal to take off of a 76cc chamber head that is prone to crack. That said they thought that bigger is better and the louder the faster. So pleaes do not take offense of the redneck statement.
Old Aug 16, 2006 | 12:02 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If I was buying a fancy new crate small block from GM I'd have to put fuel injection on it. Might as well.
To engine woes
