AIR tube plugs
Old Aug 11, 2006 | 09:20 AM
Neo Fender's Avatar
Neo Fender
Default AIR tube plugs
(Sorry for the gigantic photos)
I’m installing a used replacement manifold in my ’79. For anyone that’s interested, here’s what happened to the original manifold:
http://forums.corvetteforum.com/show....php?t=1428841
My original manifold does not have AIR tubes but the replacement manifold did. I have three of the plugs, which appear to be the original fittings filled with brass or some other material. I need a fourth plug. I assume that these fittings are originally part of a complete AIR tube assembly, so I assume that these fittings were converted to plugs after the AIR tubes were removed.
Can I just use an NPT type threaded plug? If so, any idea what size or thread I need? If not, can anyone think of another option?
Thanks,
Old Aug 11, 2006 | 11:56 AM
Crash80's Avatar
Crash80
You can use NPT 1/4" brass plugs available at your local hardware store. I like going to Home Depot for car parts.
Here is a link to a picture of what you are looking for:
http://airinc.thomasnet.com/item/fit.../109c?&seo=110
Old Aug 11, 2006 | 09:56 PM
Sayfoo's Avatar
Sayfoo
I used regular steel pipe plugs with the extended head for a wrench, not the recessed ones. Then I ground them down flat and painted the whole manifold.
Old Aug 12, 2006 | 07:04 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I used regular plumbing plugs. Took the manifolds to sears hardware and matched them up.
To AIR tube plugs
