Top end questions/ideas needed
Old Aug 11, 2006 | 12:00 PM
jmh63's Avatar
jmh63
Default Top end questions/ideas needed
Retiring the L82 out of my '74. Picked up another 350 the other day and would like get it around the 300hp range if possible before I drop it in. The 350 I got ran strong with no smoke and I don't want to get into the bottom end at this point, so just looking for top end ideas.
What I got is:
3970010 block
I268 date
V0927TKT stamp
Not sure on CR, maybe in the 8 range for this engine
'78 Truck block which I believe is a LS9 165hp
Will be running Hooker sidepipes and would like to keep my Q-jet & air cleaner so it all fits as stock under the hood. So any ideas to get this thing up to about the 300hp flywheel level
Thanks...Jack
Old Aug 11, 2006 | 12:02 PM
72_el_camino's Avatar
72_el_camino
I would think 300fwhp would be very, very easily done with just about heads, cam and valvetrain upgrade.
edit: Id recommend looking at the packages that are made to work together, ie. edlebrock
Edelbrock Power Package
http://www.jegs.com/webapp/wcs/store...tegoryId=64856
Holley SysteMax II Kit
http://www.jegs.com/webapp/wcs/store...tegoryId=15937
Old Aug 11, 2006 | 12:13 PM
slowup's Avatar
slowup
U should be more interested in hp to the rear wheels instead because after 300 hp to the flywheel its really not that much to the rear wheels.
Old Aug 11, 2006 | 12:43 PM
desi's Avatar
desi
I have stock bottom end on my L-48 motor. With 76cc Performer heads (9.2-9.5 CR????), Magnum 270H cam, Performer Intake, Hooker headers, crappy Q-jet, TH400, 3.08 gears, mech fan, alternator, ps, water pump, it makes 250 rwhp.
According to 20-35% loss, that's 313-384 fwhp. Your 300 target is very easy with stock bottom end.
Good luck.
Old Aug 11, 2006 | 12:45 PM
72Tornado's Avatar
72Tornado
Good luck.
35% loss?!? Where did you possibly get that number from? 20% is definitely more realistic
Anyway, 300 at the crank should be dead easy. One of the top-end kits that you can buy would get you there - I've heard good things about Trick Flow's kits
Old Aug 11, 2006 | 12:46 PM
72_el_camino
I dynoed 266 and I was rated at 330, so yeah about 20% is right on
Old Aug 12, 2006 | 09:01 AM
jmh63's Avatar
jmh63
Default Thanks all
I will check into some of these kits...Jack
Old Aug 12, 2006 | 08:49 PM
bozzman3's Avatar
bozzman3
Vettes have more loss then 20% from crank to wheels because of our extra drive shafts,also standard or auto makes a difference as well
To Top end questions/ideas needed
