Square port intake hood clearance
Old Aug 12, 2006 | 03:45 PM
alaskacorvette's Avatar
alaskacorvette
Default Square port intake hood clearance
Does anyone know which square port intakes will clear a stock BB '71 hood. Thanks, Jim.
Old Aug 12, 2006 | 03:47 PM
Corey_68's Avatar
Corey_68
The LS6 "pancake" will and the old Torker II will (I believe they offered a rectangle port). Choices are VERY limited, thus why you see so many aftermarket hoods.
Old Aug 12, 2006 | 05:10 PM
lvjohn's Avatar
lvjohn
I also have a 71 BB with the factory hood,and i am using a Edelbrock Performer with a drop base air cleaner and a 2.5 air filter.
Old Aug 12, 2006 | 06:24 PM
alaskacorvette
Default Oval port or square?
John, does your car have square port heads? Corey, is the LS6 pancake the only oem intake or was there several versions from GM? Thanks, Jim.
Old Aug 12, 2006 | 07:47 PM
69ttop502's Avatar
69ttop502
Yes the LS6 was the only factory square port to fit outside of the tri power setup. These intakes give up alot of power to a high rise though.
Old Aug 12, 2006 | 07:50 PM
lvjohn's Avatar
lvjohn
I have oval port heads.
To Square port intake hood clearance
