Shift kit
Old Sep 7, 2001 | 01:59 PM
Aaron76's Avatar
Aaron76
Default Shift kit
well here goes this weekend I will be installing a B&M shift kit wish me luck and if there are any pointers out there let me know. I sure hope I don't F@!k things up.
:cheers:
Old Sep 7, 2001 | 02:24 PM
Swamp Thang's Avatar
Swamp Thang
Default Re: Shift kit (Aaron76)
If your tranny pan doesn't have a drain plug (most don't), then prepare for a major tranny fluid spill when you pull down the pan. There's no way around it, have plenty of drain pans or towels ready.
Good luck !!
Old Sep 7, 2001 | 02:32 PM
Paul 75 L82's Avatar
Paul 75 L82
I bought one for my 88 IROC and chickened out after I read the directions. Good Luck!
Old Sep 7, 2001 | 05:22 PM
nunus79's Avatar
nunus79
Good time to change your filter, add an adjustable modulator, add a drain plug, and check the general condition of the tranny by noticing the type & amount sediments in your pan. A tablespoon of metal filings can be expected. Make sure you get adequate clearance between the "S" shifter linkage & the closest valve body bolt.
Old Sep 7, 2001 | 05:31 PM
jerryp58's Avatar
jerryp58
I installed a B&M kit in mine last winter. I have some info posted at http://users.erols.com/jerryp58/corvette/bnmkit.htm.
I think the best thing I did was get a stiff piece of cardboard (maybe 3' or 4' square), cut a 6" or so hole in the center, place it on top of my drip pan, and push the center down a little so that anything that came down, fluid & parts, wouldn't go bouncing off in every direction. It worked pretty well.
If you don't have a drain plug, you've probably read about loosening the drain pan bolts a little, then starting on one side and work your way around loosening them so that one side drops first. That's about the best you can do to narrow down the flow & the mess.
MAKE SURE THE FLUID ISN'T HOT!
Ditto on the Adjustable Vacuum Modulator suggestion and the pan bolt. Just be careful where you put it. I was an idiot and didn't put mine in the proper spot, had interference problems with the valve body, and had to have the hole plugged up
Take your time, read & re-read the directions.
Hope some of this helps. Good Luck!
Old Sep 8, 2001 | 02:34 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
http://forums.corvetteforum.com/zerothread?id=146260
To Shift kit
