4 speed Mods
Old Aug 14, 2006 | 03:29 AM
CarShowDVD's Avatar
CarShowDVD
Default 4 speed Mods
Any way to change the 1:1 fourth gear from to a 0.71 or 0.57
Like a OD gear?
Lowest usable gear ratio?
Anyone ever try this?
Sound crazy or make any kind of since?
Old Aug 14, 2006 | 08:36 AM
69ttop502's Avatar
69ttop502
Go to www.autogear.net. They make an overdrive 4 speed Muncie.
Old Aug 14, 2006 | 04:36 PM
CarShowDVD's Avatar
CarShowDVD
Thanks not too much info there.
Looking to get better MPG on highways.
Old Aug 14, 2006 | 04:51 PM
Kalway's Avatar
Kalway
If I were to try and make the 4 speed muncie an OD unit I'd change all 4 gears to a ratio that the 700R4 or 2004R use. That way it doesn't have an ackward shift feel.
Old Aug 14, 2006 | 04:57 PM
72Tornado's Avatar
72Tornado
Couple different ways...completely change all the gear ratios, or (much better idea) install a GearVendors Under/Overdrive unit. They're very trick, and will essentially make your tranny an 8-speed, giving you a "1st-and-a-half," "2nd-and-a-half," and so on. It shifts using a planetary gear set (like an automatic) to go from whatever gear you are in into the overdrive version of the gear - think of it like having two rear ends that you can switch between however you want. The units are pricey but can be picked up on eBay for under $1000.
Old Aug 14, 2006 | 05:14 PM
BerniesVette's Avatar
BerniesVette
I installed a T5 in my '79 for $1,200.00. Best mod I have ever done. Went from turning 3400 rpm at 70 to 2100 rpm!
Old Aug 14, 2006 | 05:23 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have added a Keisler 5 speed OD tranny to mine. Works like a champ.
Old Aug 14, 2006 | 05:33 PM
Gordonm's Avatar
Gordonm
Would not go back to a 4 speed.
Old Aug 14, 2006 | 06:08 PM
carbster09's Avatar
carbster09
Default Gear Vendors ... ?
I really like the Gear Vendors idea. Has anyone done it or have pictures?
carbster
Old Aug 14, 2006 | 07:02 PM
Kalway's Avatar
Kalway
carbster
Looks rather heavy and I'm not sure how well it'd fit in our transmission tunnel. I'd rather just go with a transmission designed with an overdrive.
The gearvendors idea has been around since like the 50s/60s. Old Triumphs came with those things.
Old Aug 14, 2006 | 07:16 PM
Gordonm's Avatar
Gordonm
Check out the cost of the Gear Vendors. It is about the same as an OD tranny. I doubt it will fit in the trans tunnel. It is pretty tight back there.
To 4 speed Mods
