Block ID
Old Aug 14, 2006 | 09:08 AM
corvette_maniac's Avatar
corvette_maniac
Default Block ID
Where can I find the casting numbers for my block? The title says `75, the front and rear clip are from a 80-82 and the carb is a 17080204....so at this point I haven't got a clue what's under the hood.
I don't think it's a 305 as I had one in a `77 Camaro and it feels a bit more powerful....but I won't know for sure until I see the numbers.
Old Aug 14, 2006 | 09:37 AM
L88Plus's Avatar
L88Plus
There's a ledge on the back of the block where the tranny bolts up. The casting number is on this ledge on the driver's side. It should be 7 - 8 numbers. Post it and we'll see what we can find out. HTH
Old Aug 17, 2006 | 12:32 PM
corvette_maniac
Ok..I found the numbers on the R front and it's V0107CHB so it looks like it is a `75 L48.
Old Aug 17, 2006 | 01:37 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Go to www.mortec.com for casting info. The casting #'s on the back of the block will give more info.
Old Aug 17, 2006 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. '75 L-48 with AT.
Assembled January 7th at Flint.
Old Aug 17, 2006 | 03:25 PM
Artsvette73's Avatar
Artsvette73
The carb looks like it's off an 1980
To Block ID
