I've decided on a set of magnaflow 2 1/2" inlet/outlet stainless mufflers for my '70. Which model fits these cars? Their site is kinda vauge w/out any fitmet options that I can find.
I had the same problem when looking for SS mufflers for my 72.
I selected the standard muffler with correct offset and welded on my
own brackets to mount to the factory hangers. I then welded on a pair of tips that I got from Stainless Works.
I see from your pics that you have a Dewitts Rad/Fan setup. Are the fans connected to the starter or the battery, also what do you have the temps set at? Thanks
I have their relay wiring kit for the fans. Power will come off the alternator to a distribution block I plan to mount in the driver's wheel well area for the headlight and fuel pump relays as well as the fan ones. The temp lead will come from the painless harness which is connected to a reflashed PCM from madz28, set at 170deg on.
The car, unfortunately, has yet to be run or driven. So close yet so far...
