Garbage Headlight Switch
Old Aug 14, 2006 | 01:27 PM
cherrybomb78's Avatar
cherrybomb78
Default Garbage Headlight Switch
I recently installed a new headlight switch to cure my dim dashlight scenario. The fix was great. But now a week or so later, bingo, no headlights. They raise and lower fine, but no lights! It appears the cheap Taiwan Mid America junk switch fell apart. One of the terminals actually fell off. Now, when I installed it, the wire harness was very taunt, no slack. But I was more than careful plugging the switch to the harness. Has anyone else had any problems plugging one of these up? It shouldnt be that tough!!! RRRRRRRRRRRRRR!!!!
Old Aug 15, 2006 | 12:39 AM
79 Bullet's Avatar
79 Bullet
where did you buy it from?
Old Aug 15, 2006 | 12:42 AM
Bob Onit's Avatar
Bob Onit
Too bad Mid America doesnt warranty labor
I have NEVER dealt with a worse company as far as parts go...
Old Aug 15, 2006 | 01:28 AM
SIXFOOTER's Avatar
SIXFOOTER
Use The Old Switch Body And The New Switch Dimmer Coil And Make A Good One.
Old Aug 15, 2006 | 07:47 AM
79vetter's Avatar
79vetter
I got mine at Napa for about $13...
Old Aug 15, 2006 | 08:30 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
A friend of mine recently bought a switch from the Chevy dealer and one from Autozone. The switch from Autozone has Made In USA stamped on it, the one from the Chevy dealer has Made In Taiwan on it.
Figures........
Old Aug 15, 2006 | 09:17 AM
cherrybomb78
I just called Autozone, here in Wisconsin and they claim it's not avai;lable in thier system. Is there a part number you can get from Autozone where you live?
Old Aug 15, 2006 | 10:38 AM
isosceles's Avatar
isosceles
here is the Autozone link. It asks for zip, I used mine =33990. Don't think that should matter.
http://www.autozone.com/servlet/UiBr...%2480154%24PPP
If available from NAPA, I'd go with that one.
http://www.napaonline.com/masterpage...adlight+Switch
Old Aug 15, 2006 | 10:42 AM
cherrybomb78
I appreciate the link, but same thing, not available. I was really excited to possibly find one made in USA.
Old Aug 16, 2006 | 01:02 PM
cherrybomb78
I agree !!!!!!!!!!!! It took 4 times for them to get my carpet correct.
Old Aug 16, 2006 | 02:14 PM
IrishJoker's Avatar
IrishJoker
NAPA has it buddy - same switch for my 81.
Item MPE HL6613SB $11.49
Old Aug 16, 2006 | 02:28 PM
cherrybomb78
Yes, I went to pick one up #MPE HL6613SB and it does not have the vacuum provisions for our headlights, it's for the olds & buicks. Napa claims it's aftermarket only for the Vettes !! I did however find one at a Chevy dealer, not a Delco (no longer available) but a GM approved manufacturer $59.99. We'll see how this works.
Old Aug 16, 2006 | 03:03 PM
gyopp's Avatar
gyopp
I was way to quick to replace worn parts with new ones in my rebuild project. I haven't done anything like this before and I was really shocked to find that most of the parts available are junk and require some degree of modifications or repairs before they are usable. Mid Am is not the only one pushing this stuff. My biggest disappointments have come from Corvette America interior parts.
Old Aug 21, 2006 | 01:02 PM
cherrybomb78
Irish Joker,
Now I know why they call you the Joker, real funny. NAPA has nothitng for our C3's !! Period.
The HL6613SB has no vacuum ports for the hideaway headlights.
Old Aug 21, 2006 | 04:59 PM
VolVette's Avatar
VolVette
The headlight switch is not easy to replace either... And each time you replace it, you run the risk of ruining a $400+ dash board.
I know some may really hate me saying it, but Doc Rebuild has had high quality parts.
Old Aug 22, 2006 | 03:03 AM
Kilroy1024's Avatar
Kilroy1024
Irish Joker,
Well, I went to 6 places in vain looking for a headlight switch for a 76 Corvette.
I gave up. I bought one for a 76 camaro and merged the two. (In stock!)
Took the metal housing with the vacuum switch off the Vette switch, and stuck it the new one.
Old Aug 22, 2006 | 03:11 AM
Kilroy1024's Avatar
Kilroy1024
The headlight switch can be changed without pulling out the top of the dash, which means you don't need to pull out all the window trim.
Prop the door open, drop the steering column and the instrument cluster and you can sneak the head light switch out the side.
Saves a bit of time, and risk to the dash panel.
To Garbage Headlight Switch
Old Aug 22, 2006 | 05:04 AM
Burnt71's Avatar
Burnt71
Old Aug 22, 2006 | 05:34 AM
Bob Onit's Avatar
Bob Onit
How do you manage to hook up all the vacuum lines..... I had a hell of a time getting behind the dash.
Thats one place I dont want to visit again.
Old Aug 22, 2006 | 10:15 AM
Kilroy1024's Avatar
Kilroy1024
Hmm. I can't remember 100%.
I think I was able to get my hand into the gap and attach them with the headlight switch in place.
