You can't find anything because there are a mountain of variables. It depends on the gear ratio in the rear for one, how heavy you are on the throttle for another. It also depends on the engine and the car it's in. If you think your 400 is shifing too high or low, it may be a leaky vacuum modulator, though that only accounts for a few mph, a non-functional kickdown, sticking governor, or maybe it's just working the way the factory designed it to.
