I don't think I am getting any detonation but how do I know. The car is quite loud at 5 to 6600 rpm and there is no way to hear it. The fuel is runing rich right now at about 11.5 to 12 AF ratio so it should not be leaning out. Is there any other way other than broken/melting pistons that yo know. All the plugs look good and clean. Only running 10.5 to 1 compression with aluminum heads and the cranking compression is 180 pounds. Just want to make sure I'm not breaking pistons.
Check your plugs carefully for little tiny specs of metal, that is a sign of detonation.
You can also buy an aftermarket knock sensor.
This is why I question this. I have/did see small specs on the plugs. Took it to the engine builder to have a look. He looked at the plugs and said it looked like it was leaning at the top end. Possible detonation? Looking at al possibilities. He was not worried about engine damage but said to get it fixed shortly!
Twin Turbo had a schematic on this site a while back. Very simple circuit and you may be able to hook it up to a bright light to alert you. Hmmm, I may try to interface it to my shift-light.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
From your initial posting I would have bet that there would have been minimal chance of detonation, due to the A/F ratio you mentioned, the high RPM (your volumetric efficiency is lower there, reducing your cylinder pressure), and the use of aluminum heads. BUT, if your builder says he thinks you have some problems I would listen to him. Double check the usual stuff (timing, A/F ratio, octane, etc). It gets expensive if things melt.
I built one of these things about ten years ago (still have it in my '84 turbo). I hooked it up to the biggest and brightest LED I could find, and fastened it (the LED) onto my inside rear view mirror. I always know when the engine is knocking , as the LED is bright enough to notice even when I'm focused looking out the windshield. I'm convinced it saved my engine several times (I pull my foot out of the throttle if it blinks too long) while I was dialing in the spark and fuel curves.
i hear one of the aftermarket companies is doing research on detonation /knock detection, the problem is not every engine has a knock in the same frequency range. different cylinder bores and engine combustion chamber design change the freqency a sensor will need to look at to hear the detonation, plus you also need to factor in the sounds from a mechanical lifter or suspension rattles.the technology is coming but there is still a ways to go, present knock sensor tecnology is designed around a new modern car. we have had problems with cars where the knock sensor was picking up outside noises and retarding the timing. on this car when the knock sensor was insulated from the noise it had a ton of power but when it was mounted to the engine the engine power was way down.
i am on the conservitive side in my advance curves because i have had to tune to many engines that were just rebuilt again because of damage from detonation where the driver swears they never heard a ping.
Don't know if this is a good theory or not. I'm sure somebody will chime in and let me know. Mine rattled a little bit at low rpm's when it was jetted overly rich, now that I've jetted down and put in IFR's, the detonation is gone. I'm thinking that the extra fuel was able to find It's way into the nooks and crannies of the combustion chamber, or the quench area of the head/block gap, and creating a knock. Now with it leaned to the proper mix it doesn't do it at all. My 2 cents worth.
TJ
Originally Posted by olescarb
...................... the problem is not every engine has a knock in the same frequency range. different cylinder bores and engine combustion chamber design change the freqency a sensor will need to look at to hear the detonation, plus you also need to factor in the sounds from a mechanical lifter or suspension rattles.the technology is coming but there is still a ways to go, present knock sensor tecnology is designed around a new modern car. we have had problems with cars where the knock sensor was picking up outside noises and retarding the timing..............
henry @ oles carb
TJ
TJ,
I've seen a (possibly) similar phenomenon (sp?) before with FI engines that were running extremely rich under load, usually during some sort of test sequence. There was a strange noise, eventually labeled "combustion rumble" under this condition. It sounded very similar to knock, but given the A/F ratio and spark timing we were running, we concluded it couldn't actually be real detonation. I'm wondering if perhaps you had a "real world" experience similar to our development experience?
aftermarket schmaftermarket. GM has solved it for you, there are 2 easy ways to build a knock detection led system, 1 uses the old standalone ESC box (like on 81 & 82 vettes), the other requires you to take apart a weatherpack ecm's calpak. Do a search, I posted how to do it not that long ago. Takes a little soldering...that's all.
What ever it is called, I'm glad It's gone. I knew my c.r. wasn't too high, so I was thinking I would reduce the quench area to try and get rid of it. Then I leaned out the carb, and it went away. All is well. Don't want to hijack this string, I'll get out of here. Thanks.
TJ
Might have trouble with the solid cam and knock sensor, seems solid cams state not be used with OEM knock sensors or you might get retarded timing from false signals from the cam
Since it will not be hooked to your timing it might provide info but I would think you would need to be able to distiguish cam knock from detonation somehow
one other way you can "see" detonation is with a portable 5 gas exhaust gas analyzer, the 5th gas is NOx. A high NOx reading can be a indicator of detonation, a 5-gas analyzer is not cheap but it is a great tuning tool. the proper use of a exhaust gas analyzer can help you find what air/fuel mixture and ignition advance a motor wants/needs for the gasoline being used.
thanks for a interesting question and also the interesting answers
