Jeep steeering box question
Old Aug 16, 2006 | 12:03 PM
Durango_Boy's Avatar
Durango_Boy
I have a power steering box from a 1997 Jeep Grand Cherokee. Will this work on my '77?
Old Aug 16, 2006 | 01:43 PM
norvalwilhelm's Avatar
norvalwilhelm
NO NO. The jeep box you want didn't come out till I believe 1999 but Jim Shea could confirm this. I believe the 97 box is an old fashion design.
Old Aug 16, 2006 | 01:52 PM
pws69's Avatar
pws69
Originally Posted by norvalwilhelm
I was running about 160 km/hour or 100 mph last night on a rough secondary road ... while dodging holes you find the car responds sometimes too quickly.
Norval,
You ARE a trip!!! Definitely one person whose posts I look forward to finding daily!!
A man of my own heart, you certainly DO STUFF that many just fantasize about! Not to mention the great insight you often provide on some of your ingenious fabrication artwork!
Keep it up - it's what keep us old farts young!!
Kindest Regards,
Paul
Old Aug 16, 2006 | 01:55 PM
Durango_Boy
Okay, back into the parts bin it goes. I had it as a spare for my old Ramcharger.
Old Aug 16, 2006 | 02:07 PM
Kalway's Avatar
Kalway
Only pics I've been able to see of the jeep box conversion are in C2s, and it's very close to the headers. Hows the clearance in the C3s?
Old Aug 16, 2006 | 03:17 PM
68 NJConv 454's Avatar
68 NJConv 454
This pic was on another thread from a member.
The hoses are close to the headers.
I know my manual steering box was very close to my hooker super comp side pipe headers.
I'm sure the extreme heat from the headers will cause some fluid boil and fatique.
I am considering the jeep install but would put some sparkplug heat socks on the power steering hoses to help prevent the headers from burning the fluid up. Probably double layer the sparkplug socks.
Anyone have a jeep box with sidepipes? pics?
anyone run into problems from header heat?
Old Aug 16, 2006 | 05:20 PM
Durango_Boy
Okay, so I'm looking for a 1999 box, but from a Cherokee or a Grand?
Old Aug 16, 2006 | 06:26 PM
68 NJConv 454
Play it safe....yr 2000 and up Jeep steering box
If you do a search on the forum for "Jeep box" you will find more info on it and a better description of what you should be looking for.
Old Aug 16, 2006 | 07:12 PM
Durango_Boy
Right, but from what? Wrangler? Cherokee? Grand?
Old Aug 16, 2006 | 07:26 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
You want a gear from a 1999-2004 Jeep Grand Cherokee, PN 52088272. Here is a picture of one next to a C3 gear.
Old Aug 16, 2006 | 07:57 PM
comp's Avatar
comp
i didn't know there was that much size difference
Old Aug 16, 2006 | 10:17 PM
68 NJConv 454
wow that things a monster....i'm almost sure i will have header clearance problems with my hooker super comp side pipes if the pipes themselves are dimpled to clear the vette stock steering pump.
Old Aug 16, 2006 | 10:35 PM
  #33
Gumbo's Avatar
Gumbo
CI 6 & 8 Veteran
Nice pic, BBShark. Answers several questions I had.
(ctrl-click, add to iPhoto library)
Thanks!
Old Aug 17, 2006 | 03:10 AM
  #34
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I don't know if the Cherokee and Grand Cherokee boxes are different...but the GC box in my garage waiting to go in the 77 looks just like the one in my '00 Cherokee.
Old Aug 17, 2006 | 07:48 AM
  #35
norvalwilhelm
While it is bigger it is not thicker. If you go to the web site that has been posted a few times you will see the thickness of the box is the same as stock. Supposedly it sticks no further out from the frame then stock.
I inserted a steel plate in my frame so I actually gained alot of extra clearance.
Old Aug 17, 2006 | 08:55 AM
  #36
Jim Shea's Avatar
Jim Shea
There is a world of difference between a Cherokee and a Grand Cherokee steering system. They are two completely different vehicles.
You definately want the 1999 through 2004 Grand Cherokee power steering gear if you are going to attempt a conversion. It is the more modern Saginaw 600 gear. It is the only power Saginaw gear that has a mounting scheme that is at least close to the Corvette C2/C3 manual gear mounting.
I think that some people get confused with the previous generation Grand Cherokee power gear (1992 1/2 through 1998). It was a fast ratio Saginaw 700 gear. This gear was a direct bolt-in replacement for the old slow ratio Saginaw power gears that were used extensively on the 1960s and 70s GM muscle cars. So it has gained popularity with that generation of enthusiasts. Again this earlier version gear (and any of the Cherokee or Wrangler power gears) have no chance of fitting a C2/C3.
You might be interested in reading my thoughts on the 600 installation.
http://jimshea.corvettefaq.com/wp-co...erGearInC3.doc
Jim
Old Aug 17, 2006 | 09:16 AM
  #37
Durango_Boy
Good, I had originally planned on using the '97 GC box I have for my '71 Charger but I had not tested compatability. Once it's put back together I'll put it in and see how it looks. Good info.
To Jeep steeering box question
Old Aug 17, 2006 | 10:58 AM
  #38
68 NJConv 454
Norval, Any chance you could snap a pic of your jeep box in your car?
I too was thinking about reinforcing the frame around the steering box to avoid some flexing.
Is the side loading of these power steering units really that noticable while driving? I could understand you'd notice a difference b/w the steering box vs. rack&pinion if you were on a xcross track putting extreme loads in cornering.
Going to give Tom at corvette steering a call today and see what he's got.
Old Aug 17, 2006 | 11:05 AM
  #39
BBShark's Avatar
BBShark
When you call him, have your credit card ready. He charges $50 for questions
Old Aug 17, 2006 | 11:28 AM
  #40
norvalwilhelm
Tom is grumpy but his kits are good. He is not much on talking to customers but he will take care of you. If you buy from him he will give customer satisfaction, just don't call with dumb questions without buying.
