O2 Sensor placement
Old Aug 15, 2006 | 05:32 PM
celeryman22's Avatar
celeryman22
Default O2 Sensor placement
Guys, I am replacing my gauges with dakota digital and I have an extra hole to fill. I was thinking of an Air Fuel mixture sensor gauge. I currently have true duals but I am going to add a "H" pipe to the exhaust. Where should I install the O2 sensor. I would like to add it to the exhaust after the headers and use something like this.
http://store.summitracing.com/partde...0&autoview=sku
Or should I install the bung in the center of the "H" pipe?
Mike
Old Aug 15, 2006 | 05:46 PM
Gordonm's Avatar
Gordonm
I have mine in the right hand tube about 10 inches back from the header collector. This gets a good mix of all the cylinders on the one bank. If you adjust your carb evenly and the motor is in good tune the other bank should be the same. Also put in in the 9 12 or 3 oclock position or anywhere in between. Mine is in the 3 oclock position. You don't want it at the bottom collecting moisture from the exhaust.
Old Aug 15, 2006 | 06:47 PM
VetteNut72's Avatar
VetteNut72
These are Hooker sidemounts, but this is where I installed my O2 sensor for my EFI system. Just about midposition on the collector at 3 oclock.
Craig
Old Aug 15, 2006 | 07:49 PM
Z-man's Avatar
Z-man
Is the sensor heated (wideband)? WB sensors can be mounted anywhere, whereas standard sensors should be within the hot area of the exhaust to make them function properly.
Old Aug 15, 2006 | 08:37 PM
celeryman22
Not sure if the sensor is heated or not. I guess I can always put them in the pipe just after the collector and monitor the one side.
Mike
Old Aug 15, 2006 | 09:58 PM
77 vette's Avatar
77 vette
Mike
Heated sensers are eather 3 wire or 4 wire. I'm going with a 4 wire for my TPI aft of the collector. Just a simple ground, possitive and the normal 2 wires for the senser, this allows the 02 to heat to the proper temp to function.
Old Aug 16, 2006 | 12:01 AM
Z-man's Avatar
Z-man
Mike
The heated sensors have a unit which powers them. If you don't have this, then your sensors are "standard". I'd put them as close to the junction of the 4 pipes in the collector as I could. I think the H pipe would be too far downstream...
Old Aug 16, 2006 | 09:55 AM
UKPaul's Avatar
UKPaul
If it's a non-heated sensor then Some people have had problems with the O2 sensors on '81's (oh, really?!!!) when they've installed them too far back in the exhaust system. the sensor cools down at low revs and starts giving false readings. I fitted mine in the reducer on the d.side Headers. Summit sell pairs of reducers with the bungs already welded in.
To O2 Sensor placement
