'72 4spd reverse lights
Old Aug 16, 2006 | 08:44 AM
tonyk72's Avatar
tonyk72
Default '72 4spd reverse lights
I thought I had my backup lights hooked up right until I noticed they are on all the time! I know the switch works fine because if I remove the rod and manually adjust the switch the lights will shut off.
Is it just the positiong of the switch that is messing me up?
Old Aug 16, 2006 | 09:08 AM
Bob Onit's Avatar
Bob Onit
Did you try swapping the wires on the switch?
EDIT OOPS! I missed the part about "shutting off manually"...nevermind
The post is only 3 1/2 lines long and I still mised a part.
Old Aug 16, 2006 | 12:57 PM
mdj21's Avatar
mdj21
yes, probably just needs to be adjusted.
Old Aug 16, 2006 | 04:09 PM
VCuomo's Avatar
VCuomo
(And it was a PITA on my '72! )
Old Aug 18, 2006 | 03:53 PM
tonyk72's Avatar
tonyk72
This is driving me mental!
I still can't get it right...
The reverse lights will come on when I first engage Reverse and then they will go out. Why won't they stay on?!?!
Old Aug 18, 2006 | 04:35 PM
wabco40's Avatar
wabco40
I did the switch adjustment using a multimeter. Select reverse and do a conductivity test across the terminals (you may have disconnect the wire from the switch) then adjust the switch position until you just get conductivity. The problem I found was that the control rod from the reverse linkage to the switch only produces a small amount of movement so its very fine line between the switch being opened or closed.
To '72 4spd reverse lights
