Idle problem
Old Aug 17, 2006 | 09:58 PM
BARRY L-48's Avatar
BARRY L-48
Default Idle problem
I have an 80 coupe,350 motor,the car runs great,but when I stop at a light or stop sign ,the idle stays high and gradually comes back to normal after about 15-30 seconds.I rebuilt the carb(Q-Jet) , is this a possible choke setting problem or something else,again the car runs great until you stop.Any thoughts?
Old Aug 17, 2006 | 10:11 PM
Bob Onit's Avatar
Bob Onit
Standard or auto?
If you tap the throttle does it idle back down?
TexSon's Avatar
TexSon
Check the vacuum advance.
Old Aug 17, 2006 | 10:19 PM
BARRY L-48's Avatar
BARRY L-48
Yes I forgot to include that in my post,it's an auto and yes will sometimes have to tap gas pedal to get it to idle down.
Old Aug 17, 2006 | 10:28 PM
Bob Onit's Avatar
Bob Onit
Lubricate all the carb/throttle linkage
I know a stronger return spring will fix it but this shouldnt be necessary
This has been a common problem for me no matter which QJet I am running....Sometimes it wont act up for weeks and then it just appears...
Also, make sure your air cleaner is not interfering with any of the linkage.
I have found that newly bushed primary throttle shafts need to be lubricated a few times before they act correctly
Old Aug 17, 2006 | 10:31 PM
BARRY L-48's Avatar
BARRY L-48
Thanks for all the input,I'll check all that tomorrow
To Idle problem
