which adjustable vacuum can?
Old Aug 18, 2006 | 06:13 PM
big69's Avatar
big69
Default which adjustable vacuum can?
I have a MSD-8572 distributor with vacuum advance. I need to replace the vacuum can with an adjustable one. Which adjustable vacuum can is the best and will fit this distributor?
Old Aug 18, 2006 | 06:25 PM
Gordonm's Avatar
Gordonm
The adjustable cans are not worth it. They do not work very well. Set it up with the correct can and use it. I had the Crane adjustable unit and ditched it after about a week. I setup with the correct can and it works much better.
Old Aug 18, 2006 | 10:22 PM
pdege's Avatar
pdege
I'm just adding a new Summit dizzy with vac advance. Does this hook into a ported vac (base of carb) or manifold vac?
Old Aug 18, 2006 | 11:00 PM
...Roger...'s Avatar
...Roger...
Try manifold first that should work the best.
Old Aug 18, 2006 | 11:06 PM
...Roger...
I installed a Crane also and thought I would have to do the same.It had 35* degrees in it and only the vacumn was adjustable-I had to solder in a stop to limit it to 12* for my application.I saw one in Summit that is their brand that says it is adjustable for both vacumn and limit of advance.
Old Aug 19, 2006 | 12:35 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have an adjustable vac can out in the garage that I am not using. I believe I can dig the springs and allen wrench out that go with it if you would like. $10 plus shipping. PM me if you are intersted.
Old Aug 19, 2006 | 10:02 AM
big69's Avatar
big69
Eddie, Thank you for the offer... This would of been super but I went and ordered one from summit before your post.
The way it sounds from the other posts, I'll be ditching it and picking up a fixed correct one anyway. The adjustable one sounds like a good concept...but not if it doesn't work well.
To which adjustable vacuum can?
