Quadrajet runs rich
Old Aug 19, 2006 | 08:24 AM
Jchrisd's Avatar
Jchrisd
Default Quadrajet runs rich
Real quick guys. I bought a new q-jet ,a nd can't remember which way to turn the screws to make it leaner. It is a 75-78 qujet.
Old Aug 19, 2006 | 08:35 AM
gerry72's Avatar
gerry72
Clockwise to lean out the idle mixture. But there is a method to achieving a proper idle mixture setting...either by vacuum gauge to achieve the highest vacuum or by a precise tach on the low scale to achieve the highest idle speed.
This adjustment affects the idle mixture, not the main metering to any measureable degree unless it's really out of whack.
If the idle mixture screws don't seem to have an affect on the engine idle or vacuum, then you have a metering issue.
Old Aug 19, 2006 | 08:58 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by Jchrisd
I bought a new q-jet It is a 75-78 qujet.
May I ask where you bought it from?
Old Aug 19, 2006 | 09:50 AM
marshrat99's Avatar
marshrat99
and want to underscore that adjusting the screws only affects the idle mixture. If you're thinking that you've got a rich conditions off idle then first check that you're choke is opening completely when warm and that your timing is correct. Too many carb problems are actually timing related.
Old Aug 19, 2006 | 10:08 AM
Jchrisd's Avatar
Jchrisd
i HAVE TO PUT THE CHOKE ON IT TODAY. I purchades a carb from caur USA and they sent me one with a hot air tube type choke. After waiting 3 weeks for the carb, I just accepted the fact that they screwed up. I am going to install the electric chole from my other q jet today at work. It is rich, trust me with no choke on it.
Tell me, when I install the electric choke o this, it there a correct way to set it, then adjust my idle. Any input would help. I won't start working on it to later today, so hopefully I can get some opinions. Thanks
Old Aug 19, 2006 | 01:38 PM
Jchrisd's Avatar
Jchrisd
Any Input???
Old Aug 19, 2006 | 04:49 PM
Bob Onit's Avatar
Bob Onit
Im sorry but I'm having a hard time understanding what you are trying to say
Does the carb have a Choke blade (the flap that closes over the FRONT part of the carb?
If it does then you can use a thin piece of wire to hold it open for a test.
You have said that it is rich without a choke so getting a choke installed will not help this problem unless the Flap I mentioned is partially or fully closed.
Do you have any way to show us pictures of the carb?
Keep us informed and good luck
Old Aug 21, 2006 | 10:27 PM
Bob Onit's Avatar
Bob Onit
Isn't it amazing how people just disappear without any explaination...much less a thank you..............
People go out of their way to help a member and the wind up without knowing if they were of any help or not..............sad
Old Aug 22, 2006 | 12:06 AM
sly vette's Avatar
sly vette
Born on Halloween Bob,must be a or the
Old Aug 22, 2006 | 08:22 AM
Jchrisd's Avatar
Jchrisd
I am sorry for not saying thank you. You are correct, I owe you a "I am sorry to all."
I wasn't able to work on the car the last few days, got stuck doing some house work.
Yes the carb has a choke blade. It has an operating choke, but is a hot air choke. What happened is I ordered a rebuilt carb, and requested a 75-78 q-jet with an electric choke, where a hot wire plugs into the side and heats the coil. I got a carb that has a port on the side of the choke (looks like a vacume port) but I believe it is meant for hot air.
Anyway, I removed the 3 screws from my old carb and the electric coil, and installed them on this carb. When I turn the dial, it does in fact work the choke blade, but I wans't sure how to set it up from the start. (Where do you set the position of the blade say when the motor is cold and the key is off??
Again, I am sorry for being rude, and I am glad you brought it to my attention. I some times take things for granted.
I will check back sometime today.
Old Aug 22, 2006 | 08:32 AM
Bob Onit's Avatar
Bob Onit
Bah........ were just breaking ***** and having fun (At your expense) so I owe you an apoligy
I am having a hard time understanding your choke description.....
But if the engine is cold and the key is off the choke should be open about 1/4"
It shouldnt take longer than 90 seconds or so for the choke to open fully with the key in the ON position
Other than the choke issue does the carb perform well?
Old Aug 22, 2006 | 09:38 AM
Jchrisd's Avatar
Jchrisd
Yes, it seems to run okay on the highway(haven't reakky driven it very far). But when I pulled into the shop the other day, it was really rich, and everyone noticed it.
I just don't have alot of exp. with the q-jets.
Old Aug 22, 2006 | 09:39 AM
Jchrisd's Avatar
Jchrisd
Oh, I forgot to ask. Have you ever been to Carlisle? I am going this weekend. I hope to find some weather strips and seat cusions and odds and ends there.
Old Aug 22, 2006 | 10:23 AM
sly vette's Avatar
sly vette
Even though you seem convinced that you have a carb problem,let me state what the Q-Jet Guru(Lars) says over and over "90% of performance issues deal with ignition and not with carburation"
Oh and by the way...Sorry about that Thing,Just bustin' ***** like Bob said.
Old Aug 22, 2006 | 10:28 AM
Jchrisd's Avatar
Jchrisd
No problem. I am not upset...
About the timing.. It is at 10degrees at idle and advances to about 34 total. I tell ya, the car has much more power with the headers and the true duals and the non electric carb and the rv cam and 3.73 gears.( I did that so far, now just tring to get it all working perfectly. I had a holley on it, and it had even more power, but not off the line.
Old Aug 22, 2006 | 10:37 AM
sly vette's Avatar
sly vette
At what rpm is the 34* coming in at???
Old Aug 22, 2006 | 01:15 PM
Jchrisd's Avatar
Jchrisd
you know what,I can't remember..I will check it again tonight when I get home. I am back and forth at the computer at work, so I can't respond quickly all the time. I am suppose to be doing this short block in a 2001 Lexus es300 (sludge motor). My boss get upset that I spend so much time on the net..Ha HA
I will fill you in later .Thanks.
To Quadrajet runs rich
Old Aug 22, 2006 | 07:18 PM
Bob Onit's Avatar
Bob Onit
I agree with Lars comment.. but.... in the case of buying a re-built Qjet I would put money down that the carb is either jetted too rich or it has one or more of a dozen or so other problems
Lars has another paper entitled Q-Jet Problems.
If you read it I believe you would be very surprised what can go wrong commercially rebuilt QJ's... abd the main problem? WAAAAY too rich ad idle even with the idle screws seated all the way in...
It might be on BarryK's site or in the FAQ on this forum.
I have seen it first hand.... usually these carbs are crap.
I bought a reman from a parts store.....It was rebuilt by a company called Champion
It was mounted on my car for about a half hour .... just long enough to figure out it was a POS
Old Aug 22, 2006 | 07:33 PM
71redskin's Avatar
71redskin
i purchased a rebuilt carb from corvette america for 71BB and couldn't get it right for the life of me... finally sent it to the guru and found out it was for a 73 truck...go figure
Old Aug 22, 2006 | 07:35 PM
Rockn-Roll's Avatar
Rockn-Roll
Have you tried a new air cleaner? If you hold one up in sunlight you should be able to easily see through all of it...if there's some dark spots or it's gray looking then you need a new one...and yes it will create a very rich condition if you can't see through it at all.
