fan blower problem
Old Aug 19, 2006 | 06:56 PM
dholifield's Avatar
dholifield
Default fan blower problem
Ok, I just finished my first project on my 72. took the radio out, got it working and changed some bulbs behind the gauges and in the console. I now this wasnt the most complex fix, but for a new guy, it was quite rewarding to get everything working. Now I need a little help with my ac/heater blower. When I purchased he car it was working, but just quit on me. I read in a previous post about an external fuse, 30 amp, located under the hood. I found one that was on the drivers side fender, hooked with other wires on what I guessed to be the horn relay. The fuse is good on it. Also found a plug at the end of the console under the radio, 3 wires connected to it, that is not plugged into anything. Was I looking at the wrong fuse? Could someone also tell me where the blower is located? Oh yea, the blower wasnt blowing very hard, even on high. Thanks for everyones help.
Old Aug 19, 2006 | 10:06 PM
shoptek's Avatar
shoptek
The fuse you found by the horn relay is the fan motor high speed supply.
If it is good, the next logical place to check is the relay mounted on the evaporator case under the hood and the ground and supply wire on the blower motor itself. The evap case holds the fan motor--it is located on the passenger side firewall.
Of course, make sure you didn't pull anthing loose from the fan switch on the center console when you did your bulb repair.
Old Aug 19, 2006 | 10:15 PM
dholifield's Avatar
dholifield
Thanks Shoptek, this board is really a big help to me. Do you have a recomendation on a repair manual that will show details such as the relay? Thanks again
Old Aug 19, 2006 | 10:52 PM
shoptek's Avatar
shoptek
most of the "store bought" repair manuals are fairly generic. I'll look in my assembly manual and wiring diagram tomorrow and if something looks helpful....I'll scan and e mail you a copy
Old Aug 19, 2006 | 11:13 PM
Artsvette73's Avatar
Artsvette73
If you want a good wiring manual I would suggest the
NCRS 1973- 1982 Corvette electrical wiring diagrams. It was purchased at Riks LIT 461 It has all you need to know. 73 Is as close to 72 not much change if any
Old Aug 19, 2006 | 11:54 PM
dholifield's Avatar
dholifield
Thanks Art, I'm really in the learning phase, so all the help I can get is much appreciated. I havent bought any manuals yet, waiting to hear everyones opinions on them. Thanks again.
Old Aug 20, 2006 | 12:17 AM
carl a's Avatar
carl a
blower motor/squirrell cage is located on passenger side----------
Old Aug 20, 2006 | 12:36 AM
dholifield's Avatar
dholifield
thanks Art, I'm going back and forth from the garage to the computer.
Old Aug 20, 2006 | 01:04 PM
RMS73's Avatar
RMS73
The Chevrolet Service Manual has a simplied schematic of the blower controls than the wiring diagrams, or at least in the 73 manual. Get the Chev Service Manual for a reference book.
Unplug the wire at the blower motor and check for voltage at the plug with the car running. Try all the different switch positions. If only high speed does not work then the relay probably will be the problem. If no speeds work then they will be an issue at the switch.
Roger
Old Aug 20, 2006 | 02:15 PM
doug_dayson's Avatar
doug_dayson
There's a resistor pack on the AC Evap Case as well, so when you run through blower speeds excepting high the juice will pass through this resistor pack (for high speed the resistor pack is bypassed, though the inline fuse is in use). These resistors can fail as well rendering one or more fan speeds other than high kaputt, even if the console switch is good.
Doug
Roger
Old Aug 20, 2006 | 05:53 PM
dholifield's Avatar
dholifield
OK, thanks again for everyones help. i've located the blower, I think, and it looks at though it has two wires running into a wire female plug that goes on the male end at the top of the blower. One of the wires plugs into the other using a black plug about 3/4 to an inch long. the wire that goes in there was hanging on by a few strands, and now broke off all the way by me handling it. Now my question is where under the hood can I find a negative ground to use with my volt meter? Also, the wire that broke, does it actually plug in the way I described or is this a permanant connection that it broke from? Once again thanks for all the help and patients.
To fan blower problem
