Project Air Scoop
Old Aug 19, 2006 | 10:49 PM
rihwoods's Avatar
rihwoods
Default Project Air Scoop
A few days ago I fit a sheetmetal air scoop below my front license plate right under the 78 valance opening...well, I whacked it driving out of Kragens driveway...I knew that plastic would be better...the following pic's show my new scoop....
Sheetmetal scoop
New plastic scoop from dust pan....
This air scoop has reduced coolant temps approx 5 degrees...small gain,but an improvement....and the plastic version is more forgiving...
Rich
Old Aug 19, 2006 | 10:52 PM
gonzo14's Avatar
gonzo14
DAMN INGENIOUS my friend, good job!!
Gonzo
Old Aug 19, 2006 | 11:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This will be the next thing in the Ecklers catalog for sale. Good job on the scoops. If it works and does a good job,
Old Aug 20, 2006 | 12:21 AM
rihwoods's Avatar
rihwoods
Gonzo
The reason I did this is my 78 has a steel plate behind the license plate bracket...so I can not run without the front plate and get more air to radiator like my 69...it acts much like a "ram air" device as frontal opening is small and air dumps into a larger "plenum" in front of radiator..
Rich
Old Aug 20, 2006 | 12:28 AM
rihwoods's Avatar
rihwoods
I'm thinking of calling Rubbermaid to see if I can get a deal on their reject plastic dust pans...say $1 each...I can cut,drill mounting holes, smooth edges and sell them for $6 each for the rubber bumper vettes......
Old Aug 20, 2006 | 09:30 AM
fugawi's Avatar
fugawi
mine does'nt overheat, but i'll buy one to help out...
Old Aug 20, 2006 | 10:02 AM
Durango_Boy's Avatar
Durango_Boy
I'll let you in on something that will complement you scoop. Getting the ai out somewhere else will allow that scoop to give you waaay higher temp gain than 5 degrees. The engine bay in a Corvette is notorious for holding air, and creating a large hot pocket above the firewall, just beneath the windshield line.
At that upper edge of the hood, where is seals down in front of the windshield is a lip, or ridge, maybe an inch wide. I can post a pic if you're confused.
http://img.villagephotos.com/p/2006-.../underhood.jpg
On that rib, ridge, lip...whatever you want to call it, make some vent holes. Nothing huge, but several inches side. Maybe two 5"x1" vents in that top lip. Cover it with wire mesh, and rivet it in place. It's on the belly of the hood so you can't see it from the outside unless you are sitting in the cabin.
Doing this will allow that scoop to bring in more air and force hot air out of those new vents. I think you could expect a 15 degree drop in temp at speed.
Old Aug 20, 2006 | 10:59 AM
rihwoods's Avatar
rihwoods
Have thought of something similar..have you done this ?
These pics show my 69 cowl hood...note yarn is "vacuumed" into hood opening...second pic is at 50 mph....
Understand the idea...
Thanks, Rich
Old Aug 20, 2006 | 11:14 AM
BerniesVette's Avatar
BerniesVette
I drilled one inch holes across the raised area on the bacl of the hood. The hood keeps its rigidity but allows hot air to flow out from that area where heat builds up. It does not change the running temps while the car is moving because of the high pressure at the base of the windshield, but it does allow hot air to escabe in stop and go traffic and while sitting still. Popping the hood after stopping is an easier way to accomplish this.
Bernie
Old Aug 20, 2006 | 11:29 AM
rihwoods's Avatar
rihwoods
Bernie
In my tests with the 69, I took this picture at engine idle before road tests..note yarn...air at idle does come out...
Engine at idle...900 RPM..
Durango_boy....
I don't have a low speed/traffic problem with the 78 overheating...I'm experiementing with speeds of 65-70 +...
Rich
Durango_Boy
This is what first got me into this thinking.
On the Corvette I have I have not done this. I changed to a good stat, and a chemical coolant and I run at 180 allt he time. My first Vette though got the cowl vent treatment, and it helped a lot at speeds up to 35. Couple that with a scoop in the front under the radiator, and I'd bet it'd work to twic those speeds.
what kind of coolant do you use?
Old Aug 20, 2006 | 11:55 AM
theandies's Avatar
theandies
Rich,
Looks great but I do have one suggestion........I think I'd make the brackets attach from the inside. I mean have the brackets come from the inside of the scoop. That way you cannot see them on the outside of the scoop to make for a cleaner looking installation. I know the only time you would actually see it if you get drunk and fall down in front of the car though.
Old Aug 20, 2006 | 12:15 PM
Durango_Boy
Originally Posted by theandies
Rich,
Or, pull the whole panel, and glass it on. That's the cleanest of clean looks.
Old Aug 20, 2006 | 12:25 PM
rihwoods's Avatar
rihwoods
Rich,
Agree...good idea...
Those are temporary...was in a hurry to get scoop tested/resolved...plus,I'm using existing valance bolts(2) just outboard of air scoop...I'll fab up better ones to work from inside...these were off the shelf,pre-drilled,etc...
In fact..I can make some from the 18 ga metal scoop I whacked !!!
Me ...get drunk ??? Hurts at my age....
rich
Old Aug 20, 2006 | 12:27 PM
Durango_Boy
rich
Never too old to drink my friend. "Beer, helping old guys feel young and handsome, since you started wearing diapers again... "
Old Aug 20, 2006 | 12:33 PM
rihwoods's Avatar
rihwoods
Oh,I drink beer..in fact..Negra Modelo...but I stop just before my mind turns into a muscle....
Old Aug 20, 2006 | 12:34 PM
Durango_Boy
That's frig'n funny man. *High Five.*
To Project Air Scoop
