? Replacing temp sending unit
Old Aug 21, 2006 | 11:23 PM
BLUSHRK's Avatar
BLUSHRK
Default ? Replacing temp sending unit
through searching I've come to the conclusion that maybe my coolant temp is not really what the factory gauge shows. I've got a new one, but it comes with no instructions. Obviously it only screws in one way, can't screw that up, but what should I use on the threads? Anything at all?
Also, the headers come pretty close. (3 inches) Could that raise the reading that is showing on the gauge? Has anyone experienced lower temps by maybe putting one of those spark plug boot heat shields on the wire/sending unit? Would that help? Just thought I'd ask before I try to figure out how to actually get a wrench in there to loosen the unit.
Old Aug 21, 2006 | 11:34 PM
71406's Avatar
71406
I never put anything on the threads...and you want it to get a good ground anyway. You probably know this but some coolant will leak out during the change. Use a protective cover on the wire if you think the header will burn thorugh the insulation...other wise it should have no effect on the guage reading.
Old Aug 22, 2006 | 10:29 AM
SIXFOOTER's Avatar
SIXFOOTER
Your correct, the temp gauge shows Head temp in the center and not necessarily coolant temp. The coolant temp will be somewhat lower than the gauge reads and will not fluxuate as much as the gauge.
Old Aug 22, 2006 | 12:17 PM
kdlp's Avatar
kdlp
Assuming your heads are stock, just spin it in... if you're running aluminum heads, I'd use some anti-seize.
kdlp
Old Aug 23, 2006 | 02:20 PM
TexSon's Avatar
TexSon
The last couple of times I have changed the temperature guage sending unit I have used teflon tape. Gives it a good seal and there is still a ground made. Just a wrap or two is all it takes so the threads cut through to ground but it prevents any leaks.
Old Aug 23, 2006 | 02:27 PM
pws69's Avatar
pws69
Bad idea - it can "isolate" the sensor from ground and cause incorrect readings.
Best is good old Plumbers Pipe Cement - you can buy it anywhere and it's inexpensive. I use "Rectorseal" myself because my brother gives me the almost used up cans from his plumbing trucks!
Old Aug 23, 2006 | 11:01 PM
TexSon's Avatar
TexSon
I've used teflon tape on both temp and oil sending units and have never had a ground problem.
Old Aug 27, 2006 | 11:29 PM
clintwilson's Avatar
clintwilson
Default temp.guage.reading.
if it is a 79 or 80 .the sending unit is differant.looks the same plugs in the same.has differant ohms value. local suppliers will sell you the part but wont work. check volunteer corvettes.(www.volvette.com)
Old Aug 27, 2006 | 11:43 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
That's the problem I have in my '80. My stock guage reads 40 degrees high. I run a second mechanical guage that sits where the clock use to. I went through a lot of trouble to figure out my guage was wrong and the car was not overheating. Finally I dropped the sending unit into a pot of boiling water and looked at the guage. The thread still exists with pics here.
To ? Replacing temp sending unit
