Electric choke
Aug 22, 2006 | 01:03 PM
Electric choke
Anyone install a carb with electric choke? I need to find a wire in the engine compartment that is hot when the switch is on. (besides the obvious ignition wire). Anyone help?
Aug 22, 2006 | 01:17 PM
I ran a new small fuse box that is powered from the starter post. The fuse box runs off a relay that is connected to the ignition so that it is only activated when the key is on. I also run my electric fans from that box.
Aug 22, 2006 | 01:20 PM
As I remember on my '76 you can use the yellow wire from the wiper motor plug
LL&P
Tom1701
Aug 22, 2006 | 02:20 PM
I ran mine thru the firewall and connected it to a spade terminal on the fuse box.
Aug 22, 2006 | 02:27 PM
Thanks. Any idea of amp draw? I have two chokes and I am wondering if I need separate wires all the way back to the origin.
Aug 22, 2006 | 04:22 PM
Quote:
LL&P
Tom1701
I run mine right here with no obvious issues.
Aug 22, 2006 | 05:58 PM
Quote:
The wire that came with the choke was 14 gage, so that's what I ran to the fuse box.
Aug 22, 2006 | 06:53 PM
Electric Choke
i Ran Mine To The Hot Side Of The Coil, Is That Ok It Seems To Work Good
Rick
Aug 22, 2006 | 07:06 PM
St. Jude Donor '08
LL&P
Tom1701
That's the same info I got for mine and that's the one I used
