400 engine weight
Old Aug 22, 2006 | 09:28 PM
Demonic Possession's Avatar
Demonic Possession
Default 400 engine weight
Need some help here, just bought a jackstand (1000lb) and I just want to be sure that it could hold a 400 engine on it or should I get the 2,000lb one? Tried googling it, but no luck.
Thanks!
Edit: It would be a complete engine, and not just a block.
Old Aug 22, 2006 | 09:38 PM
Little Mouse's Avatar
Little Mouse
an iron 400 small block would weigh around 550 pounds.
Old Aug 22, 2006 | 09:41 PM
Demonic Possession
Old Aug 22, 2006 | 09:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Are you just setting the motor on it or working on it ? If working on it I like to make sure the stand has four legs ( so to speak ) and is at least 1250lbs. rated. When you start spining the motor over to put in pistons and cranks etc. a nice stable stand is desirable. For storing them I use 750lbers.
To 400 engine weight
