Brake problem
Prior to this, I have
Replaced front calipers and pads
Replaced all brake lines
Replaced a leaky proportioning valve
Bled brakes using Motive power bleeder
I'm wondering what to do at this point. I think that I may have air in the lines and that I may need to rebleed or that the master cylinder needs replacing. I just don't know why the brake light would go on with a full master cylinder. Any help and advice would be greatly appreciated. Thanks.
Before you buy or rebuild anything, re-bleed. Corvettes had a very specific bleed order in mind when they designed the system. I would suggest doing it the old fassioned way this time, and try this order.
Driver's Rear
Passenger's Rear
Passenger's Front
Driver's Front
At least five Pump/bleeds per side.
If after a good bleed you still have a mushy pedal, it wouldn't hurt to rebuild the master. It only costs $25 for the kit, and take about an hour.
In the meantime, here's a test for you to check the booster.
With the engine off, pump the pedal until it gets hard. If it doesn't get hard you have a bad booster.
Once the pedal is hard, start the engine. The pedal should go soft and go most of the way to the floor if you have air in the lines.
If it gets hard with the engine off, and soft when you start it...your booster is most likely okay. It's a good idea to rebuild that master, but only if a bleed doesn't help.
Also, inspect ALL wheels for ANY signs of fluid loss. If you don't already have stainless steel sleeved pistons in the calipers you may be getting air in the system via a bad seal or runout....also known as rotor wobble.
If it happens all the time I would suspect an air bubble, but if it’s intermittent you may have to look into the master cylinder or vacuum assist.
J/K
1. check rear rotors for SS sleeves
2. Measure runout on all 4, less than .002"
3. new seals on the rear calipers
4. Rebleed
You can get your pedal back for noww by rebleeding but that won't fix the problem, I would personally go with the o-ring conversion kit on all 4.
4. Rebleed
Do like Mark Hamill would...use the Force.
Seriously, you'll have to remove the caliper, and take out the pads. Peel back the seal, and you shoud see a prominent edge where the sleeve starts.
Another way is past knowledge of the brake work done. If the rear brakes have never been changed then they are NOT sleeved.
actually i thought it was
passenger rear (inside bleeder then outside)
driver rear (inside bleeder then outside)
passenger front
driver front
i didn't notice that in your first post. I always read you go from the caliper farthest from the master cylinder and work your way back.
passenger front
driver front
That's how you get air trapped in the system. The manual suggests couter clockwise from the left rear.
Whoa...this is a warnign sign. Did you say that whent he engine is off, you pump the pedal and it never gets hard? That's a warning sign that your booster's rubber diaphram is not holding the pressure, and may be leaking. You may be looking at getting a new booster man.
I'll have to check that when I get home. I haven't bled my brakes for a while.
Yeah, it's rears first...you're right, but you start on the driver's side, switch sides, then move forward on the passenger side without X-ing over. Do the front passenger side third, and then cross back over to driver's side for the last bleed in the front.
You're corrct that it's not 'X' pattern.
