Removing torque converter bolts
Old Aug 23, 2006 | 08:12 PM
dgruenke's Avatar
dgruenke
Default Removing torque converter bolts
I was going to remove my torque converter-to-flex plate bolts last night. I removed one and went to turn the engine over to remove the next bolt. I put a long bar on the front crank bolt to try to turn it over. The motor wouldn't budge, it only further tightened the crank bolt until I couldn't turn it anymore. I don't have the sparks plug out. Will removing the spark plugs make that much of a difference or should I try bumping the engine with the starter. If I have to use the starter, I have to take the battery to get recharged because it has sat for awhile.
Do I have to worry about using the starter when there is only one bolt left, or will the flexplate stay straight even though the other bolts are already removed?
Old Aug 23, 2006 | 08:21 PM
Bob Onit's Avatar
Bob Onit
Removing the plugs will make a huge difference
Then you can get a wrench on the front of the crank shaft to rotate the engine and loosen them all (you may even be able to spin the engine by grabbing hold of the toruqe converter)
With the plugs you may need to give the wrench on the flex plate bolts a good whack with a hammer but they will come loose
Old Aug 23, 2006 | 09:31 PM
dgruenke's Avatar
dgruenke
I'll have to give it a try. I just didn't want to waste my time, sweat and blood removing the spark plugs if it wasn't going to make a difference.
The one flexplate bolt that I did remove wasn't too stubborn. I broke it loose with a wrench before I remembered that it has a nut on the other side.
Old Aug 23, 2006 | 10:13 PM
MsVetteMan's Avatar
MsVetteMan
Old Aug 23, 2006 | 11:06 PM
TexSon's Avatar
TexSon
Removing the plugs work, but be prepared to find a way to lock down the flexplate as turn on the bolts will also turn the engine over and make it hard to remove the converter bolts.
Old Aug 23, 2006 | 11:59 PM
dgruenke's Avatar
dgruenke
Thanks for the help. I will have to try that.
To Removing torque converter bolts
