Rear end noises
Old Aug 23, 2006 | 09:49 PM
Ritz's75's Avatar
Ritz's75
2nd Gear
Default Rear end noises
I have a 1975 L48 with a 4-speed. The car has 66,000 original miles.
When the car is cold it works great, but after 45 minutes of driving I'm hearing scraping or grinding from the rear end, when starting, mainly in 1st gear but also audible in 2nd, at very low speeds. Noise goes away at higher speeds! Park the car for a few hours (until rear end cools) no noise! U-joints are tight and wheel bearings are good! I believe noise is in the differential. Any suggestions appreciated before I take the rear end apart.
Cheers
Rob
Old Aug 23, 2006 | 09:56 PM
...Roger...'s Avatar
...Roger...
Cheers
Rob
I would change rear end fluid-use 2 qts GM fluid with 2- 4oz containers of additve.Put the additive in first then top off with fluid.
Old Aug 23, 2006 | 10:03 PM
Ritz's75's Avatar
Ritz's75
2nd Gear
Thanks, I'll certainly try the additive (2 four ounce containers) I'm not sure if there is any additive in the rear end now.
Old Aug 24, 2006 | 12:34 PM
corv58's Avatar
corv58
i'll second that....did the same to my '79,and all noises/clunks disappeared...... jim....
Old Aug 24, 2006 | 12:51 PM
blue by you's Avatar
blue by you
Agree with both after changeing the fluid find a parking lot and do tight figure 8's that get the fluid into both sides
To Rear end noises
