Stock Radio Work-a-round.
Old Aug 24, 2006 | 12:19 PM
Vmo's Avatar
Vmo
Default Stock Radio Work-a-round.
I've been trying to put the radio in my 74 back to stock. It presently has an aftermarket CD player in a hacked up center console. I bought a new uncut center console, and finally found a stock radio to install.
It is from a 76 though. I've got the power and light and ground figured out, even got the speaker wires figured out, BUT, it has a 6 wire connector that is supposed to go to a "multiplexer", that I don't have and can't seem to find available. Is there a way to make this radio (am/fm stereo) work without the multiplexer??? Any semi-bubba fixes to make this work??? The radio doesn't appear to have a plug for the heat sink that goes behind the map pocket, so I guess that function must be combined in the multiplexer? I really would appreciate some help/advice here as I really would like to get rid of this aftermarket radio. I have done a search and not found the answers , please help!
Dusty
Old Aug 24, 2006 | 12:29 PM
Durango_Boy's Avatar
Durango_Boy
Dusty
This is just a suggestion, but you know that Mid-America Corvette parts catalog has an exact stock replica of your stock stereo, that has a new modern digital tuner and aux hookups for an Ipod or MP3 player. It mounts just like your stock one, with the ***** through the holes, but plays like an aftermarket HU. It's pricey, but would give you the stock look, almost exactly, and you wouldn't have to track down 30 year old parts to put together a worn out stereo.
http://www.madvet.com/shop?frame=4.307.3486
Old Aug 24, 2006 | 10:01 PM
7T1vette's Avatar
7T1vette
The "multiplexer" term throws me. I purchased a '73 AM/FM Stereo for my '71 coupe last year (the previous owner scrapped the original for a Kenwood! Go figure....). It has a separate stereo power amplifier unit which mounts under the right side dash pad. It has a 3-wire lead and connector which hooks into a 3-wire lead/connector on the radio head. I believe that the three wires are "ground" and a signal side for each channel. The only electronics on the power amp heat sink are two power transistors and a couple of capacitors. If you have a 3-wire set coming out of the back of the radio head...that's them! If you don't have the power unit, I think you should be able to find one on e-bay for not too much $$$. This all assumes that your '76 radio is designed the same as my '73. Someone else may be able to tell you the "skinny" on that. By the way, the early '70's Corvette radios had 10ohm speakers--not that easy to come by today. You can probably replace the existing speakers with 8 ohm speakers, if you don't run the radio near max output (if you do, you'll fry the "peewee" power transistors). Good luck!
Old Aug 24, 2006 | 10:39 PM
Durango_Boy
That's dumb. I don't even like some of today's Infinities, door speakers, that are 2 ohm. Most HUs won't like that.
Old Aug 25, 2006 | 09:19 AM
tomzss's Avatar
tomzss
Default multiplexer
If your radio is really from a 76 then the item you need is an amp (heat sink)
http://cgi.ebay.com/ebaymotors/Corve...20284178QQrdZ1
if its from an earlier year (69/70 ?) then it actually is a multiplexer that you need. In those years all mono AM/FM radios had a built-in stereo preamp but if you got the AM/FM stereo option they just added the mutiplexer which contains everything else needed to turn the mono radio into stereo.
You can differentiate by looking at the radio's case. If you see fins and something like the ebay pic on the side of your radio then it is an early one and the radio should work in mono without the multiplexer.
If all the sides are flat with no fins then it is a later one and the above amp will be needed to make it work. But beware these amps came in two versions one for mono radios and one for stereo (the ebay one is stereo)
The multiplexers are probably rare. In 1970 the AM/FM stereo radio was $278.10 which doesnt seem like much until you realize that it is almost the same price ($289.65) as the 454 option!
Old Aug 25, 2006 | 09:39 AM
Vmo's Avatar
Vmo
The plug on the radio appears to be the same as the one in the picture, but is there any way to avoid spending another 100 dollars to get this radio working?? Between the money I've already spent on the radio bezel, and the radio, I really hate to spend even more to get a crappy 70s sounding radio. I was hoping someone has some kind of a magic fix to make a cheaper alternative. Thanks for the inputs.
Dusty
Old Aug 25, 2006 | 09:54 AM
tomzss's Avatar
tomzss
Sorry, a 76 radio will not work by itself.
If you know someone handy with a soldering iron you can tap into the preamp and then run it into any aftermarket amp. it wont be factory original but no one will see it either.
I can look at my schematics (which are at home right now) and tell you where to connect the wires if you want to try it.
Tom
Old Aug 25, 2006 | 09:56 AM
rihwoods's Avatar
rihwoods
Default Satelite 8 track..
Dusty
There must be a way to solve your issue cheap....In my case,stock 8 track still worked,so added new pioneer speakers and this....
Some are cheap at $49....
Rich
Old Aug 25, 2006 | 11:21 AM
Durango_Boy
Why didn't you like the aftermarket HU?
Old Aug 25, 2006 | 12:13 PM
Vmo's Avatar
Vmo
HU??????
Old Aug 25, 2006 | 12:18 PM
Durango_Boy
HU??????
Head Unit. Sorry.
Or radio...CD player, Tuner...whatever you like to call it.
Old Aug 25, 2006 | 01:38 PM
Kalway's Avatar
Kalway
First time I've ever seen anyone want to go BACK to the original stereo. If I really wanted the stock look I'd do as suggested earlier and get the midamerica modern replica.
Old Aug 25, 2006 | 01:50 PM
Durango_Boy
So you're trying to get back to stock stereo, are the speakers stock too? If not you may run into problems there too.
Old Aug 25, 2006 | 02:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are companies that redo vintage car stereos with modern guts. I've been thinking about it for my dad's '54 GMC, I need to get the original tube radio out and see if it works first.
Old Aug 25, 2006 | 02:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "multi-plexer." 68-76 stock AM/FM units have one external transistor in a heat sink for the U69 and two of the them for the U-79 (stock stereo). If memory serves, each transistor has a three wire connector.
Purchase the assembly instruction manual (AIM) and study the diagrams of the stock installation.
Old Aug 25, 2006 | 03:49 PM
toddalin's Avatar
toddalin
Tom
Exactly what I did on my '64 radio. I have a 4-channel JBL amp mounted under the passenger seat and when I did this modification a couple weeks ago, the old radio sounded far better than it ever did. The old power stage was making all kinds of noise and hiss, but the preamp stage is very clean.
I put the JBL amp in when I had an aftermarket stereo. The stereo was a piece of junk and even with just a tone control, the "new" "old" mono (in 4-channels) sounds far better than the aftermarket stereo did.
While I was in the radio, I added a wire to the "on" switch that would also send 12 volts to trigger the amp aleviating the need for a separate switch.
Old Aug 25, 2006 | 04:18 PM
Durango_Boy
Wouldn't happen to have some diagrams or schematics you could post huh?
To Stock Radio Work-a-round.
Old Aug 25, 2006 | 07:04 PM
toddalin's Avatar
toddalin
It's documented in the C1-C2 section. It was on a '64 radio.
Old Aug 25, 2006 | 07:10 PM
Bob Onit's Avatar
Bob Onit
I did
And the Amp was still sitting behind the pass side dash
It doesnt sound like the Kenwood that that was in it when I bought it, but its stock
Old Aug 25, 2006 | 07:23 PM
Durango_Boy
Originally Posted by Bob Onit
I did
Maybe I'm too new fasioned, but I love the aftermarket stereo I installed. Sounds great. Doesn't look stock, but sounds wonderful.
