Engine compartments....stock look or slightly modified??
Old Aug 25, 2006 | 02:05 AM
Little Mouse's Avatar
Little Mouse
Originally Posted by ajrothm
Ya you are right bro but...black headers look like *** after the coating wears off. Not to mention the ceramic helps keep the heat in the pipe and not as much on my feetsies. I am not necessarily going to "disguise" everything in there. I just want it to look correct and detailed in a stock like fashion.
Can you paint aluminum heads and it look good and not flake off? If I could paint the heads, I would probably paint the intake and the water pump also, then the only non stock looking thing would be the headers which is pretty common on restos today.
I was thinking they had ceramic coating in black. I think they
spray aluminum with etching primer before painting.
Old Aug 25, 2006 | 02:19 AM
Little Mouse
your 195 AFR eliminator heads with the AFR stampings on front
will be filled in before painting ??
Old Aug 25, 2006 | 02:22 AM
ajrothm's Avatar
ajrothm
Not sure, haven't thought that far ahead yet. LOL I am still thinking of restoring my interior before I do my motor. My old stocker is running pretty good honestly. I can't wait till it cools down some, gonna take it back to the track and see what it does in cooler air. I have changed the intake, lifters and re-timed it since my last 15.0 outing. I think its got a 14.80 in her.
Old Aug 25, 2006 | 08:50 AM
ML67's Avatar
ML67
I generally prefer an engine bay that at least gives a nod towards the factory appearance. For me its always been about striking a balance between functional improvement and (factory) appearance. Its hard to “hide” headers, aftermarket heads and intake manifolds. In my case, I kept the stock valve covers, air cleaner, alternator and cooling systems and loosely based the engine appearance on an L-88.
Variety being the spice of life, I like well executed modifications as well as a factory correct restoration.
Take care,
Mark
Old Aug 25, 2006 | 09:12 AM
Ganey's Avatar
Ganey
Slightly modified for a sleeper. L-82 valve covers, no name chrome air cleaner, stock chrome ig. shields, al. intake, etc. Many don't know Corvette setups (esp. year specific) anyway.
Old Aug 25, 2006 | 09:13 AM
stingr69's Avatar
stingr69
I love the stock sleeper look that runs like a scalded dog!
I was considering to do the sleeper stroker thing with mine but when it came apart the block/insides looked too good to throw away. I did swap the heads out though. Those Dart Iron Eagles are hard to spot with all the acessories and dummy polution controls in there.
Once this one wears out I will definately stroke it
Some day.
-Mark.
Old Aug 25, 2006 | 09:24 AM
vetteonr's Avatar
vetteonr
After I first got my car 10 years ago, I went for the shiny look.....
Then, when I put my new engine in, I went with a more tame look......
I like the wolf in sheep's clothing look better.
Old Aug 29, 2006 | 11:20 PM
Frank O'Hara's Avatar
Frank O'Hara
ajrothm - I'm running Comp Cams Pro Magnum Rocker Arms 1.52 without a girdle. The locking nuts were too tall for the stock valve covers so I used a 1" spacer (1/2 inch probably would have worked but I could only find a 1"). I had to use a 1" longer AC belt so I could clear the valve covers - works great.
Old Aug 30, 2006 | 11:03 AM
71rdster's Avatar
71rdster
Plus I don't think they will fit under my AC brackets.
A longer belt will allow the ac to clear the valve covers, but watch out, the belt will eat the A-arm dust cover.
Old Aug 30, 2006 | 12:48 PM
Kid Vette's Avatar
Kid Vette
I too like the slightly modified stock look. By the way, there are Harland Sharp roller rockers under those valve covers. You need to use the thick Fel-Pro gaskets tho.
Stock
Mine
Old Aug 30, 2006 | 02:50 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
I'd say go for a completely stock look and have a sleeper on your hands!!
Old Aug 30, 2006 | 03:11 PM
steve J06's Avatar
steve J06
someone mentioned painting aluminum heads....
Can you paint aluminum engine parts? Why don't you usually see that? Is it the bling factor? I am considering a lightweight aftermarket block and like many in the thread would like some semblance of stock-ness. I know the educated eye will pick it out but the educated ear will also be able to tell before even looking, It was a 165HP smogged wonder after all.
steve
Old Aug 30, 2006 | 07:18 PM
  #33
ajrothm's Avatar
ajrothm
Actually, I now decided to hold up on my build up for a while. I have a few bills i need to pay off and then I am going to start saving up for the build. I want to do it right the first time so I decided on building a 496" BB. It will have aluminum heads/intake and water pump but I will run the factory chrome valve covers because I love em on BBs. I have been pricing the stuff out and I can build forged 496" with aluminum Dart heads for $6k. I would need to buy headers for a BB or SB either way so, thats not really additional cost. The additional cost comes in the pulleys/brackets and maybe radiator. Also I will have to switch to a L88 hood. With a mild 496" I can run a relatively tight converter(3k stall) and my 3.08s to start with and it will still run hard. Lots of TQ. Should make 550-575hp with a hyd flat tap and lots of low end.
That is the plan for the moment. It will be next summer before I start now but I think I will be happier with it that way. I want this biotch to run mid 11s in the heat and be mild enough to drive everyday without swapping trannies, gears etc.
Might even get ole 427Hotrod to give me a hand since he is the BB guru.
Old Aug 30, 2006 | 08:39 PM
  #34
66427-450's Avatar
66427-450
..... I want to do it right the first time so I decided on building a 496" BB. ....Might even get ole 427Hotrod to give me a hand since he is the BB guru.
Very good plan..
let's face it, take a common 454 block, add a stroker crank and with decent heads, cam and intake you can make some very serious power.
you'll find these interesting reading.......
http://www.compcams.com/Community/Ar...ID=-2023343081
http://www.popularhotrodding.com/tec..._chevy_engine/
http://www.popularhotrodding.com/eng...olet/bigblock/
