Muncie M-21 question
Old Aug 24, 2006 | 07:41 PM
CoolShark's Avatar
CoolShark
Default Muncie M-21 question
Is the Muncie M-21 from a 69 the same as for a 72 LT-1? I have one from a 69 that I was going to swap into my 72 and the output shaft on my 72 is larger. Is this normal or has there been some changing of output shaft on one of them?
Old Aug 24, 2006 | 10:55 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Just went through this. It is normal. The muncie went from a 10 spline input and a 27 spline output to a 26 spline input and a 32 spline output in 1970. Other than that they are the same. It will work. you need a 10 spline clutch disc and a turbo 350 yoke. If you change them out I have a 11" Clutch setup complete, balanced, All GM, NEW 10 spline disc, newly rebuilt Pressure plate, Resurfaced flywheel and new throwout bearing. Will sell all for $200 plus shipping. The turbo 350 yokes are common.
Old Aug 24, 2006 | 10:57 PM
MidShark's Avatar
MidShark
CoolShark
The '69 Muncie will have a smaller dia. output shaft as you describe. I believe the change to the larger shaft was made in 1971.
Rich
Doh! answered same time as '63mako.
Old Aug 25, 2006 | 12:29 AM
CoolShark's Avatar
CoolShark
Thanks. This one was a surprise to me. Live and learn.
Old Aug 25, 2006 | 03:10 AM
5speeds's Avatar
5speeds
1969 and up take bolt on shifter shafts. However depending on the shifter, the bolt pattern where the shifter mount plate goes is different on a 32 spline tail as well.
To Muncie M-21 question
