TH400 and Exhaust Question
Old Aug 24, 2006 | 11:04 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default TH400 and Exhaust Question
Ok how hard is it to change the pan gasket, filter, and dipstick with the transmission in the car. also how much wrap is needed to do a set of headers.
Old Aug 24, 2006 | 11:58 PM
novavet's Avatar
novavet
not hard at all just a little messy
Old Aug 25, 2006 | 11:03 PM
VCuomo's Avatar
VCuomo
And, to make it less messy the next time you want to change the filter, replace the stock pan with one that has a drain plug (if yours doesn't have one)!
Old Aug 26, 2006 | 12:11 AM
dgruenke's Avatar
dgruenke
Just make sure you loosen the bolts on one end of the pan before you remove the bolts from the other end. Then, the pan will hang down a couple of inches and pour into your drainpan.
To TH400 and Exhaust Question
